SOLD!
Hi guys
Im selling a used Trust/Grex oil cooler kit. It comes with Earls braided lines and fittings and all pieces(incl. adapter plate) to fit onto an RB25DET motor.
This came off an R34 GT-T, and im sure it will also fit the R33 GTS-T, as they should have the same oil filter type. It is in EXCELLENT condition and is a bolt on kit.
$650
hi
here are the dimensions. it has 12 rows.
18.5cm High x 30cm Long x 5cm Wide.
with regards to the oil relocation kit, im not sure, to tell you honestly. the way this bolts on is very easy and quick. all you need to do is take the oil filter out, put the trust/grex plate over where the oil filter sits, use the nut it comes with and tighten it(DONT TIGHTEN IT HARD!) and put the filter back on. then just put the oil cooler at the front(has bracket), close to the water resevior, and you are done, easy.
i couldnt say for sure, sorry Blitz_R33.
I do have a buyer for the oil cooler who will be making payment early this week. so the cooler may already be sold, pending on payment. it will be going on a R33 GTST.
