hey guys,
Due to a change in circumstance it looks like i've gotta pick myself up a wagon so im thinking a stagea would be a good bet.
Just from looking around it seems that all stagea's except the autech 260RS were factory auto's? Has anyone attempted a manual conversion yet?
For a manul conversion i'd take it you'd need to borrow most of the gear from a 33 GTR and go from there?
lastly from a seat of the pants driving experience do they feel any bigger than a GTST at all?
Cheers!
Luke
https://www.sau.com.au/forums/topic/61327-mentally-inept-stagea-question/
U can get manuals in normal Stageas Series 2 (1998 onwards) - just will pay a few thousand more than auto - and Ive found none yet in Oz, so might have to ask a yard to find u one or go through a broker like geoff risbey from prestigemotorsport to find one in japan for you. A Tiptronic series 2 is other option (no normal auto was ever done in series 2 stageas) and these are available now.
But yeah otherwise conversion, and some of the fellas here would know about that probably but not me sorry.
Adam
Cheers!
Luke
Hi Luke, there are a few guys on here that have done auo to manuals conversion, thye can give you the details. I would suggest that if you really want a manual that you buy one in the first place.
As for driving impressions on Stageas there is a thread on it, with quite a few guys input, I suggest you have a read.
As for a direct comparison to R33 GTST, well the Stagea is 4wd, same as a GTR. They are heavy, mine is 1660 kgs, so they don't feel as nimble as a GTST. Obviously they are a waggon, so the rear CofG is higher than a coupe or a 4 door. I have upgraded the stabiliser bars to compensate for that. Due to the weight and 4wd, in the wet they are awesome, it is simply all traction. Add some upgraded shocks (Bilsteins in my case) and a handfull of alignment products (adj camber & caster) and the handling is very good. Much better than most cars and streets ahead of any other waggon.
Obviously the engine benefits exactly the same from mods like any RB25DET. Since you have traction in all circumstances, they can take advantage of ALL of those increases in power.
Hope that answered your question.:P
  • 4 weeks later...
I am going through the research of this right now too actually..... Trying to weigh up if its worth importing the manual version or doing the conversion when it gets here..... After speaking to my broker It apears the autos can be bought at aution as low as 7 grand cheaper then the manual which is what I want to... now the questions I am going around trying to solve is it worth paying the extra or doing the conversion here, should I take the gear box out of a GTS-4 and I have an added problem of wanting the slightly later model with the NEO engine which comes with the tiptronic auto... so looks like there are some added difficulties.... but I am going to go talk with my mechanic today to find out whats the best plan....
If you really must have a manual, then I strongly suggest that you buy a manual. The money will come back to you when you sell it. A "real" manual will always be worth more than a converted auto. Plus I doubt whether the cost saving would be that much. The manual S2's are not commanding as much premium over the tiptronic autos as they used to.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
