Hey guyz
Finally got my 32 on the road and have noticed that in sum gears it seems to lag.
Now im not to sure whether becoz it was sitting in japan for 5mnths without being driven and when it arrived it had no fuel at all so possible sum shit is blocking the injectors but yeh not running the best
The engine is a stock rb20.. no other visible modifications.
Not sure wat psi its running either..
When you punch 1st and 2nd gear the car seems to respond particularly well.. however when your just crawling and then put ur foot on the gas say when ur in 2nd there is a short wait b4 the car decides to move, same with 3rd gear too
Seems to me like its missing...
Um any suggestions?
Thanks Joe!
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/
Hey guyz
Um any suggestions?
Thanks Joe!
They don't have much low down torque you need to keep it up in the rev range a bit, between shift changes do you:
* Clutch in, change gear, clutch out, THEN get on the gas,
OR
* Clutch in, change gear, get on the gas and clutch out as the revs are rising?
You need to be doing the latter, after having driven a V6 auto commo for the 3 years prior to getting my skyline it took me a little while to get out of habit of just putting the foot down and expecting something to happen, I'd just put it in to gear then put the foot down and it reacted very sluggishly just as you're describing. But maybe that was just me. :D
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1159275
Also try the computer reset trick, first go grab a tank full of BP Ultimate (any 98RON will do but i like BP) and take your car home, disconnect the negative from the battery, hold the brake pedal down for a min, then reconnect the battery and take her for a thrash.
This all puts the ECU back in to self learn mode making slight adjustments to ignition.
If you eliminate you shift habits, fuel quality, ECU reset as possible causes the next step is to check the timing.
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1159335
i think they are laggy, but not as bad as everyone makes out.....with an exhaust, cam gears and hi flow panel filter it made a world of difference......on and off boost, your not gonna take on a rb25 or rb30 and beat it down low but they go well for that they are.
my 2cents
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1160300
Now think how fun it would be on the street with a decent turbo trying to make over 200rwkw. :(
You do get used to it and adjust your driving style. :D
Yogi is right.. The ol' RB20DET does go really well with a few mods for what they are. I was impressed with how well mine was.
Once on boost they rev nicely and do go well. Launching is another story. Mine would bog down with anything under 4000-4200rpm on board.
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1161259
mine was a bit like that too and I had, filter,full 3" exhaust, FMIC,1.0Bar boost etc...
I think its just the engines nature man
take it out to the track for the day and have a chance to run around without breaking the law and get used to the car would be my advice. I did everytime I added some mods and it helped
mark
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1161411
Throw the exhaust and cat in the bin, get a new system, get a Hybrid FMIC, and throw in a new fuel pump. Combined with a good service with fresh fluids and your pocket will be $2,000 lighter...
The difference will be huge. You will have about 150-160rwkws and a in that state the engine can be flogged repeatedly for years and another 50-80,000kms:)
I wouldnt really bother with a boost controller as you will find you will make around 12-13psi anyway with the breathing mods.
Yeh they can be a little breathless, but ppl, they are a 1400kg 2.0L turbo car. I love ringing the RB20s neck, it feels sporty:) Half the fun of turbo cars is the rush onto boost.:)
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1161900
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
