Hey guyz
Finally got my 32 on the road and have noticed that in sum gears it seems to lag.
Now im not to sure whether becoz it was sitting in japan for 5mnths without being driven and when it arrived it had no fuel at all so possible sum shit is blocking the injectors but yeh not running the best
The engine is a stock rb20.. no other visible modifications.
Not sure wat psi its running either..
When you punch 1st and 2nd gear the car seems to respond particularly well.. however when your just crawling and then put ur foot on the gas say when ur in 2nd there is a short wait b4 the car decides to move, same with 3rd gear too
Seems to me like its missing...
Um any suggestions?
Thanks Joe!
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/
Hey guyz
Um any suggestions?
Thanks Joe!
They don't have much low down torque you need to keep it up in the rev range a bit, between shift changes do you:
* Clutch in, change gear, clutch out, THEN get on the gas,
OR
* Clutch in, change gear, get on the gas and clutch out as the revs are rising?
You need to be doing the latter, after having driven a V6 auto commo for the 3 years prior to getting my skyline it took me a little while to get out of habit of just putting the foot down and expecting something to happen, I'd just put it in to gear then put the foot down and it reacted very sluggishly just as you're describing. But maybe that was just me. :D
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1159275
Also try the computer reset trick, first go grab a tank full of BP Ultimate (any 98RON will do but i like BP) and take your car home, disconnect the negative from the battery, hold the brake pedal down for a min, then reconnect the battery and take her for a thrash.
This all puts the ECU back in to self learn mode making slight adjustments to ignition.
If you eliminate you shift habits, fuel quality, ECU reset as possible causes the next step is to check the timing.
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1159335
i think they are laggy, but not as bad as everyone makes out.....with an exhaust, cam gears and hi flow panel filter it made a world of difference......on and off boost, your not gonna take on a rb25 or rb30 and beat it down low but they go well for that they are.
my 2cents
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1160300
Now think how fun it would be on the street with a decent turbo trying to make over 200rwkw. :(
You do get used to it and adjust your driving style. :D
Yogi is right.. The ol' RB20DET does go really well with a few mods for what they are. I was impressed with how well mine was.
Once on boost they rev nicely and do go well. Launching is another story. Mine would bog down with anything under 4000-4200rpm on board.
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1161259
mine was a bit like that too and I had, filter,full 3" exhaust, FMIC,1.0Bar boost etc...
I think its just the engines nature man
take it out to the track for the day and have a chance to run around without breaking the law and get used to the car would be my advice. I did everytime I added some mods and it helped
mark
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1161411
Throw the exhaust and cat in the bin, get a new system, get a Hybrid FMIC, and throw in a new fuel pump. Combined with a good service with fresh fluids and your pocket will be $2,000 lighter...
The difference will be huge. You will have about 150-160rwkws and a in that state the engine can be flogged repeatedly for years and another 50-80,000kms:)
I wouldnt really bother with a boost controller as you will find you will make around 12-13psi anyway with the breathing mods.
Yeh they can be a little breathless, but ppl, they are a 1400kg 2.0L turbo car. I love ringing the RB20s neck, it feels sporty:) Half the fun of turbo cars is the rush onto boost.:)
https://www.sau.com.au/forums/topic/61357-r32-laggin-probs/#findComment-1161900
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
