Dominoes can either be really good or taste like cadboard - the trick is to dont be a lazy arse and pick it up yourself ..... get it delivered by the time it gets to you its awful!
I found that myself with "EAGLE BOYS" they make some shit pizza, the one @ great estern hwy.
  • Replies 310
momma?
Get my movin stick momma wants to go to the video library and get me sum stories
:bahaha: Simpsons quotes!
"Doctor said i wouldnt get nosebleeds anymore if i kept my finger out of it"
Yep i used to work for Pizza hut at one stage, ran my Skyline into the ground sure it was a c210 but it would have lasted longert than it did if i wasnt caining it about delivering pizzas every weeknight. Still u get free stuff on occasion, after a while u cant stand it though.
For teh ultimate pizza try Pizza king in bullcreek off parry av very good pizzas
Yeh i thin PH was pretty much teh same but it was as bit more. so u got like $2-3 a delivery plus $6 an hour or something. U can usually do around 4-5 an hour so its not all that bad in teh end but it doesnt cover repairs if it breaks.
i used to work for domino's as a drive u get $1.25 per delivery... that is meant to cover ALL running costs... fuel, vehicle maintenence etc etc
riiiiigggghhh! that wouldnt even cover a sil80 on boost. :D
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
