f/s - R33 Skyline N/A
'93 R33 Skyline non turbo *$12,500*!:
- White
- two way factory sunroof
- GTR400 front bar (best for r33 IMO)
- Enkei Lightweight racing mags (white)
- Nissan sports steering wheel
- 5spd manual
- aluminium shift
- brand new strut brace
- Kenwood double din head unit
-10cd stacker, 10vcd stacker, TV in glovebox
- Kenwood 200W 6x9's
- dark tint, all skyline elecs etc.
- engine totally stock, never modified
- Genuine 155,000km, def. no wind back
- Heaps of reg. left
- Alarm system inc. remote central locking, 3 point immobiliser, windows up feature
- Absolutely any tests welcome
****Asking $12,500****
HAVE FOUND THE HOUSE I WANT, THIS HAS TO GO!
Will consider all offers over $11,500.
I have owned this car for the last two years (in march), and have bought a gts-t in august 04.
Can't afford to keep the two whales (it's kinda hard to drive em both at once anyway :) ) & buy a house, so need to sell in the next month or so.
Top first car, easy to maintain and looks awesome. Nothing to do.
Either PM me for an inspection or ring 0422 119 066 :)
  • 4 weeks later...
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
