hey i got a r32 gtr, and i recently changed its timing belt and spark plugs.
i just started it and it idles good but wont rev over 3000rpm, plus theres a loud whining noise coming from the timing belt cover.
i tihnk i over tighene the belt, which is causing the whining.
any ideas why it cuts out at 3000rpm?
i gapped theplugs correctly, 1.1mm,
i also cleaned the afms with metho, would that stuff em up?
thanx
steve
https://www.sau.com.au/forums/topic/61391-rb26-wont-rev-over-3000/
thanx for the replys but ive foun the problem. it ended up being the afm wiring. i jiggled it and it fixed the problem. im gonna have cut the bad bit out and rewire it.
i also just sligtly loosened the timing belt but its still whining. i noticed that the belt is rubbing on the little cover on the crankshaft, its one that goes on before the main pulley goes on.
i understand its to stop the belt from coming off, but this is actually rubbing the side of the bellt of so you can see the thread.
how can it be fixed???
steve
i replaced the two little plates that sit on the crack shaft and protect the timing belt(before and after the crank gear....only because i had such a bad time removing the pulley that i bent them slightly and was making the slightest whirring noise that drove me mad.
also apparently hi performance belts make some noise compared to geniune oem ones depending what they're made of.
George
There shouldnt be any noise from a timing belt.
Is the belt sitting in the middle of the cam gears and crank gear?
It shouldn't be running on anything.
The only thing that could possibly make a noise is the belt tensioner if the bearings are shot
Are you sure you haven't got the 'cover' (like a large thin washer ??) backwards ?? It will rub on the belt if it's not installed the right way round .....
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
