  • Replies 84
Fatz you do have a couple of options here , first is to replace the .50 ARR comp cover with the larger .70 ARR T04E cover and keep the backplate .
Second is to use the larger series T04S cover and backplate (adapter ring) which is what Garrett did with their GT3540R turbocharger .
If your finances are limited go the larger ARR .70 "E" cover . If the sky is your limit go the "S" bits . Also remember that the T04S covers are quite large so make sure there's enough real estate where your turbo lives .
Generally compressor covers are sized around airflow rates or speed . So for a given compressor wheel the larger the Area Radius Ratio the lower the gas speed will be and vice versa . Also the larger it is the less chance it will have of being a choke point at high wheel speeds . Someone did tell me that all else being equal going up in comp cover AR brings the boost on a little later and "hits" harder .
With most Garrett turbos there is a set compressor wheel diameter for each wheel/cover family , ie 60mm wheels T3 covers , 71mm wheels T04B covers , 76mm wheels T04E covers , 82mm wheels T04S covers .
In recent years Garrett started going up a size in cover with some of the GT BB series compressors . I think this is because the comp wheels are mechanically stronger , and and can still pump efficiently at much higher rpm's than the bush bearing has beens . This is a win win situation , the small high speed wheels are compact , cheap to produce and more importantly have less innertia so spool sooner .
Examples of this are the little GT28RS (T04B comp cover) and some of the GT2835R series turbos with 71mm compressors and T04E covers .
The Garrett people inthe US tell me that the up sized cover , and a little extra tip height on the wheel , gives extra pumping capacity and a few more points compressor efficiency .
I can only think of two examples of Garrett turbos that went smaller in cover size , they are the HKS GT2540 and the Ford GT3540R . The 2540 is getting on and was probably an attempt to get a bit more flow and power out of a small series turbo , and a low mount compact (convienent) fit for GTR's .
Its safe to say Ford was not looking for serious performance with the XR6T so a compact and probably cheaper adequate cover got the nod . You can bet they knew people would modify them for performance , so the limited cover capacity may have been intended to limit the performance with the std turbo but not affect the standard state of tune .
Cheers A .
yea just stuck a side pipe on the beast and took it out to the drift day
sadly budget has died in the arse so i will have to putt around for some time until a set of cam gears arrive and the powerfc which is probably about 3 months away
im quite happy with the power but as soon as those cam gears are in hopefull it will bring it on a bit better
if cam gears dont bring it down to 4000rpm with power fc and a decent tune then i will consider the upgrade to external wastegate and a .86 rear housing and combine it with the larger front cover
but hey im happy as a pig in shit at the moment and when i win lotto ill do the next big upgrade
ive also got a rb30 complete engine that will be getting a solid bottom end over the next few years to replace the gtr bottom end when or if it ever goes
yea baby
anyone have some cheap cam gears
pete
  • 5 weeks later...
  • 2 months later...
    • The plan is to get it out of the shed. The reality may fall some way short. But hope is as cheap as despair as they say. Will go a wide band I think. The coils are ok so maybe I’ll miss the $1500 on the R35 coils etc. Im still on the fence about a trigger kit. The HKS one looks nice ($1k) - not sure how it works with the Link or if Link prefer something else. Oil pressure is fine so I’m not that concerned there. Fuel pressure I’ll have a think about. The IAT got changed for the Link anyway as the old RB26 ones were really slow reacting and pretty poor. The Power FC just worked. Wasn’t terribly refined but it just worked. Probably made a mistake replacing it really. E85 isn’t available locally - it is 100+ kms away which puts it in the too hard basket. Lastly I understand Tunecorp in Perth are pretty good so was probably going there.   As for turbos is there are new age -5 drop in replacement? Turbos have come a long way in 20 years, everyone is big single which is fair enough but I prefer the old school complication of twins. Wasn’t chasing more power (well, not much more) but more efficiency would be ok.
    • I thought I'd share this....the shell is non genuine but they found or built a lot of the genuine parts. Plus, it is by far the best colour scheme of those years, the winfield once was particularly shit https://www.v8sleuth.com.au/written-off-inaugural-godzilla-recreated/
    • Good work Pete and glad the car held up well....been a while since I've seen you try properly
    • Just quick update, I've had tech issues and so a backlog on life stuff....I will pull lap times from the video and data from the ECU logs to do a proper update. But basically, in order of importance: 1. The car was excellent fun on the track, really felt a lot like the good old days. And nice to have AC while waiting 2. Coolant got really hot; again I need to pull and analyse the logs but the standard system is not up to tracking at 30o+ days, once the system was heat soaked after the first 2x15min sessions I could only do 3 laps before it got 110+ and I had to cool down. If I can't improve that it is a deal breaker 3 Oil temps were fine all day, noting it was short sessions due to 2. I think it will likely need work 4 Biggest surprise AT temps were fine, never went over 100, I would have been OK with 120 before I was too concerned. The auto sucks compared to a manual (of course) but it is faster to launch and I just need to downshift it manually before hitting the throttle, then it was OK. When I post the vids you'll hear it telling me off (beeping) for trying to downshift too early (it needs about 3500 before it will downshift, depending on gear a little but we are mostly talking 3/2 and 4/3) 5 A052s were not great which hurt the lap times, but I will be constrained in what I can get in good tyres that fit the wheel wells. These were small for a heavy car at 235/45/18. In theory I can fit 9.5 on front and 10.5 rear (so not square) but I still need 670mm+ high tyres in good brands. 6 Standard shocks/springs/roll bar are too soft for track work (of course), but that was always on the list. And happily, no white on the mat, despite having a teenaged passenger, extinguisher mount was fine. Also, it was nice to have Wakefield Park back in action  . Because the car was so quiet it is eligible for Green Day, which I thought was a band but is apparently a series of cheaper practice days they run with a lower sound limit, that is a smart idea.
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
