Was thinking about the plain bearing turbo that i currently run, or shoudl i say sits in thr boot of my car:(
Spinning the compressor / turbine you get a feel for the difference between it and some the HKS turbos i have seen, namely 2835/3040 & T51.
But i got to thinking the fact that its not installed and running on the car, hence has no oil pressure around the bearing... is spinning the turbine whilst the thing is in your hand indicative of the sort of friction/resistance in this sort of bearing setup?
Or once they have pressurised oil in their core do they spin easier. I guess im thinking they would spin easier, but i aint really sure...anyoen stripped a plain bearing turbo and have a good idea of the lubricated faces / oil films in the core?
https://www.sau.com.au/forums/topic/61429-turbo-bearing-ques/
its about 10,000 times easier with oil pressure. As ylwgtr2 says, when there is oil pressure there is no contact between the bronze bearing and the housing, and no contact between the shaft and the bearing.
I have one in my fingers right now.
Pull it apart very carefully for yourself, thats the best way to learn about things.
Make sure you have clean hands and clean everything with petrol, then add oil when you put it back together.
Yeh ive seen the inside of an old CA18 turbo with only a 270deg bearing etc. But its pretty hard to suss out just how easily the shaft spins with oil pressure as opposed to when sitting in your hand.
Anyway, i guess my answer the difference is dramatic, so thanks
when i was installing the gcg high flow tubby, i span the wheels, and they didnt really feel that free rolling, however, now its in the car, i can hear the turbo spin down for about 5-8 seconds when you turn off the engine ... the plain bearing did not do this ! i can only put it down to the free rolling now the turbo has oil in it !
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
