hi guys
got a bit of $$ from my holidays working and looking to make my car look a bit better as i'm starting to get bored. i know they WONT make me go faster but i've got my exhaust and filter done already and thats probably as far as i want it to go "for now".
anyways, i cant decide if i should get:
1) Work Meister S2R rims
2) Body kit
This will probably be the last mod i do for the next 3 months as uni will start.
I currently have some rims but whilst they look alright, they're pretty heavy.
Pic of my current rims:
Pic of meister S2R
Pic of kit
seriously cant decide so up for suggestions
thanks
Eric
https://www.sau.com.au/forums/topic/61489-rice-parts-dilemma/
This is just my opinion, so please don't flame. Those wheels look very similar to the wheels you already ahve on the car. You'd notice more with the kit I reckon. In terms of the lightness of the wheels, that's not going to make that much difference just cruising around the place.
That IS a nice kit . . .
Do you have a FULL exhaust? A proper dump pipe and big cat would have to speed-up spool times methinks. I'd say go the body kit if you get all "cosmetic" on your car though, as I personally don't think there's much difference between the rims.
Have you considered something like this?
the mags looks good. get the body kit for rice factor.
don't worry about the weight of the rims unless you're already at a level to try to break your own lap time record with a powerful race-spec car, where power and handling is no longer an issue, but crucial weight reduction is still to be made.
hahaha
i've already got 18s
just havent been lowered so it looks smallish compared to the 2nd pic
yes, i've got a full exhaust done already so at least thats out of the way
and yes, the works have a BIG DISH hahaha
hmm. thanks for the replies
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
