hey,
i though id make another post for this problem.
i changed the timing on my rb26 with a nissian oem belt.
whats happening is the belt is rubbing hard again the large washer thing that sit on the crank between gear and the pulley.
i opened her up again today and it looks like the belt is too wide. it takes up the whole gear as you can see in the pic.
the pulleys them selves are in mint condition.
i dont know what to do!! did nissian give me a wrong size belt?
steve
https://www.sau.com.au/forums/topic/61507-timing-belt-making-loud-noise/
The position of the belt on the tensioner and crank pulley looks correct from what i can make out. Mine sat exactly the same way on the rb25 when i swapped the belt.
Silly question, but which way have you installed the plate that sits infront of the crank pulley, curving away from the belt? As it really only acts as a guide to make sure the belt doesn't slip forward and so i assumed it should be a pretty close fit.
yeah the place faces out wards. ill try to get a better photo (used my phone for that one).
the belt is defently rubbing something cause on e side of the belt is showing its insides.
i wonder if the bearings on the tensioners are gone? they looked ok when i took em out last.
steve
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
