I don't know for sure, but from my (limited!) understanding of high school chemistry, if the temperature drops (i.e. overnight) the fuel (in vapour form - it's not always liquid) slows down thereby reducing the pressure.
Same sort of thing as tyres when they heat up - pressure rises.
Somebody correct me if I'm wrong but it seems logical to me...
:D
https://www.sau.com.au/forums/topic/6153-fuel-pressure/#findComment-92553
If the fuel pump runs all night. then the fuel pressure shouldn't drop. But it doesn't, so the pressure drops.
Really got nothing to do with high school chemistry. You lose pressure because the fuel leaks back past the non-return valve in the pump. I have found it normally takes less than an hour for the pressure to drop to nothing.
That's why the ECU runs the pump for about 5 secs before you start - to get fuel pressure back into the lines.
The fuel is always in liquid form. The car won't run on fuel vapour. (Except LPG, before any smarty pants attack me). If you were old enough to have owned a car with carbies, then you'd know that to be the case.
https://www.sau.com.au/forums/topic/6153-fuel-pressure/#findComment-92721
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
