g'day g'day peeps.
my factory boost guage in my 32 gtr isn't working.
can someone tell me if the sender is the little black box mounted to the firewall up high on the drivers side... ? and if so, where does the vaccuum line usually lead to for it... ?? .....or am i way off?
where are people usually t-piecing their vaccuum hoses for aftermarket boost guages in these cars.
cheers
david
https://www.sau.com.au/forums/topic/61534-32-gtr-boost-guage-dramas/
OK i can prolly help with this too. You are right, the black box that has a connector and a small tube running from it is for the stock guage. To run a mechanical aftermarket guage you need to t-piece the inlet pressure line to the intake mannifold. An easier one to t-piece would be the line going to the fuel pres. reg.
Again i hope i have helped.
Deren
Sorry to hijack, but my factory boost guage isn't working as well.
The hose that ran to the little black box on the firewall was cut and the aftermarket boost guage connected to it.
Are there any side effects for disconnecting the black box?
Hey nedb no need to be sorry i feel like im taking over all of djhatton's posts anyway :(
So far as i can tell the only thing that happens when the black box is disconnected, is that the stock gauge wont function. Which prolly wouldnt make much diff to your gauge by the sounds anyway. If you want both the stock and aftermarket gauges to function you need to put a t-piece hose connector into the vacuum signal hose (the one that is now only going to your aftermarket gauge) and they will both operate.
Any other problems i'll try to help,
Deren
hey where does this factory boost sender pipe supposedly lead to? mine's not going to anything and a dig around the plenum isn't finding me much... or am i looking in the wrong places?? i can find plenty of vacuum lines... just don't know where that factory one leads...
where's the best place to run a vacuum hose through the firewall for an aftermarket guage? i ahven't looked yet, but planning on fitting the one i've got lying around in the next few days...
cheers
d
The original vacuum line for the gauge runs to the back of the engine (firewall) and connects to the back of the intake mannifold (not the collector/plenum). Its closer to the block..Just use one of the original sealed holes that are in the firewall..
Godzilla32 - Thanx for the reply.
Also, the wires coming out of the little black box they would be just telling the factory boost guage what boost to show, but would they lead to the ECU as well.
I guess what i'm trying to ask is, does ECU know what boost your running and if so where does the signal come from?
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
