I have 2 cooler left from this group buy. Be quick!. If you live in brisbane $250 bargain!
Cooler have arrived and ready for delivery
Found a new supplier he has the hybrid 600x300x76 coolers a little cheaper if I buy in bulk. He is also in china so it will take ~25 days to get it to your door.
To make the deal I will need a minumum of 10 people. Also with the people who want a cooler I will need a deposit of 30% = $100. But I will not need this money until I have 10 confirmed buyers. Then the other $190 will need to be sent to me before I ship them off to you guys.
People interested.....................................amount paid(full/deposit)
1) rmahnovetsky
2) gatty might be interested
3) RedBaron Interested!
4) mr_rbman Interested...........................full posted
5) shif_tea definitely.................................full posted
6) Al definite.
7) Jetdat 1 maybe two
8) jetdat
9) shogun..................................................deposit
10) boj01
11) tikki169 ..............................................full
12) gtrGhosTDoGG11 interested
13) sky30
14) mr.r33.................................................full picked up
15) JeeTeeEss25Tee.................................full
16)
17)
18)
19)
20)
Still have a few cooler left PM me if your interested
Specifications
bar and plate design, exactly the same as hybrids without the logo.
core size: 600mm*300mm*76mm
overall size: 780mm*300mm*76mm
compressed air flow rate::P
https://www.sau.com.au/forums/topic/61546-intercooler-290-delivered/
  • Replies 111
hey mate, i mgiht be interested - i'll get back to you
//on a side note, i see your running a site form free bigpond hosting - if you want some proffessional hosting PM me, I host a few sites including sauqld.com and a few other sites form here :P
im interested wen does this group buy close??
As soon as I get 10 people well maybe.... At this rate it will be the next hour :P ... Seriously as soon as I can get enough people (10 people). But at the rate of interests I should get plenty of takers by the end of the week. So right now I will put a due date by the end of next week. 21 / 1 /04. More people get a good deal the better :)
Group buy finish 21 / 1 / 04
RedBaron: better pricing if we can get 50+ ...
srt : No way dude. But I'm working on getting cheaper piping. If you can get an intercooler and the piping kit for under $800 let me know asap.
if its the exact same one as in the pic with the moulded outlets into the end tanks and the 4 round bits to hold it to the chassis i will take it otherwise i'm a no!
yes exactly the same as the pictures. So I guess you in. Sweet.
Have a look in you nearest autobahn they sell the same coolers.. Bar and plate coolers that retails for around $599 and that is the one. :cheers:
It is bar and plate - the cooler it made in the same factory as the hybrid brand. I asked if I could get a hybrid logo but I need to purchase min 100pcs.
I can get a close shot. I will post it up.
Just as a little incentive. I know some of you don't trust shipping from overseas etc. So since I trust the guy I will put the full risk on me :rofl:. Which means if the goods don't come through then you get your deposit back.
Guest
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 馃憤
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
