  • Replies 111
Actually since we have nearly hit 10 I will start organising the shipment this week. No money is necessary at this stage since I only need to give him 30%. I will let everyone know when I need the $100 deposit. At this stage Im estimating about the end of Jan.
Actually I'm going to order another 10 coolers out of my own pocket for others if they are interested. So thats a total of 20 all up. Unfortunately it does not change the price - need to purcahse 50+. If I bought 100+ then I could get a hybrid logo :cheers: ...
can't you get 100 out of your own pocket??? :cheers:
jokes dude. Also a quick question, about warranty or any problems, how long is it and what do we do with it (hopefully no dramas but thought i'd find out)
thanx mate
I'm currently in the process of finding out about warranty from the manufacturer. But from me I always check out the good before I post them off. Make sure they are in excellent nick. So from my end the if the parts is not what I described or there is a problem when you receive it I'm happy to exchange it.
Will get back to you about manufacture warranty.
sweet dude. your on.. No deposit just yet. next week I will talk to the manufacture let him know the deal. I will post up next week more accurate dates of arrival in australia. At the moment I beleive it will arrive between the middle to end of feb.
Status
Well, we have hit 10 cooler :D Today I have contacted the manufactures to ask them to begin production on our coolers. So once they finish making them they should be on the next boat to brisbane. Once they get on the boat I will need atleast the deposits from everyone so I can pay the other %70. So here is my ETA list
production finish end of month.
Ship to Brisbane (next available ship) 1st feb : Will need at least deposits at this point up to when the ship arrives. So deposit need to be paid between 1st to 15th feb.
At brisbane 15th - 20th Feb
My house hopefully in a couple of days: 23 Feb
Your house 26-28th Feb..
this is just a guess at the moment. When the ship sails I will have a more accurate ETA.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
