  • Replies 111
That's nothing.
FIRST time i spun out on a track, out of four different track days, ass end slapped a concrete barrier, $7000 later she will look better than new. I pay $2400 a year on insurance, but can't claim as it happen at a track meet :). The fun of motorsport. I will be hitting the track again, once car is on the road :).
run of bad luck huh :) my R33 rolled down the driveway hit a tree. Had to replace the left guard and light. The panel I got is just off my body colour so I need a paint job. JUst under $900 later... Then 2 days later my friend slipped on my bonnet. Mr dint doctor has to come out now :( .. Not a happy chap
Al you young hooligan. That'll teach you for being a hoonish skyline driver!!! Nah jokes man, thats some shocking luck. Sometimes i think i should sell and buy a barina to keep me outta trouble (and a LOT better off finacially!!) muhahahah
It in woohoo!. I need to pay the rest of the money to the supplier, pay customs and then I can get it. I reckon i will have the coolers on my door step by tuesday nextg week. :)
All who have paided a deposit please pay the rest. Im running low :D
thanks guys.
Are you just getting the 600x300x76 coolers.. or are you getting a couple of the 400x300x76 units as well like last time?
I am thinking of getting the slightly smaller cooler, as the 600 could be a bit of a **** around to get on the R32 correctly. The shorter one would be so much easier to get behind the stock R32 bar..
Intercoolers are finally home :) wooohooo..All 20 of them...
For those of you who have purchased a cooler I will be sending them off on saturday morning. Too many coolers to take into work.
For those of you who still want a cooler, well get in quick as they at a price I wont be able to beat from my aussie supplier and are here now and you dont have to wait for one.
I paid immediately - you sent me crap then claim that I tried to rip you off!! :confused:
how does that work?? I pay you hard earnt money - you send crap item which is missing components and is not suited to my vehicle (you claim it was) - you leave negative in my trader rating claiming I tried to rip you off??
You are a bad trader of crap items. The forum should be aware of this.
All parts for the kit was there. Nothing was missing. If you had a look at the pictures you would have noticed everything in the kit was all there. Compare what I give you to the picture if it does not match then get upset. I don't understand how you think there was missing pieces. I'm not in the game of ripping off people. Ask others in the forum.
If you asked me how to install the kit I would have helped. But you didn't instead you blame me for not being able to install the kit! So that is why I called you a bad trader.
Since I'm not in the game of unsetting people I still offer my services to help you install your part.
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
