i have S2 R33 GTS-t.
i was noodling around trying to see how difficult it would be to replace the fuel pump. so i carefully read up all the threads on "how to replace fuel pumps".
i removed the four screws from the top plate, unclipped the two electrical connections, eased the three hoses (fuel line, return and breather(??)) from the white cap. i managed to tap that tight motherf#*^ black ring off and carefully lifted out the white plastic cap.
i was expecting the fuel pump to be attached on a cradle to the white cap. instead there was a fuel line feeding down into the tank and various wires. i presume the pump is in there somewhere. i gave the fuel line a light tug and it all felt pretty snug in the tank.
if i need to change the pump will i need to drop the tank or has the cradle fallen off into the tank.
help please...
cheers geoff,
if the tank had been about 1/4 full it might have been easier to see. ***(i was scrambling around looking for a lighter or matches but the cigarette in my hand made it hard to get them out of my pocket......)
how difficult is it to mount a bosch pump back into the factory bracket?? also what else will i need on hand to do the job??
ps. ***no, i don't smoke and i was just kidding
You may have to tilt it to get it out, as like you say there is a few houses and a couple of wires coming off it.. but it will come out if you twist and pull ..
Once you have the bracket out, mounting another pump just makes common sense as to where to place the new one; which is as close to the old position as possible.. I'd recommend using a large hose clamp (or two) to secure the pump to the bracket...
like so..
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
