  • Replies 175
I will be there cathing a ride with daler32 im no taking my 33 simply becasue im screwed for that stupid speeding thing i did and i dont want to get anything else happed before i go to court knowing my luck get caught for stopping 2 close to a corner or something and that has happed before lol.
See you at the yatala pies carpark at 7:30 gold coast people.
And to all other we are not dumb gold coast people we are just courteos to others who may want to suggest where to meet:)
oh if anyones after a uhf dick smiths sellin two uniden uhfs in a pack for 58 bucks
http://www.dse.com.au/cgi-bin/dse.storefro...duct/View/D1804
Buy these only if you wish to have all the range of leaning out your window and yelling at the other car.
They are seriously crap.
Spend $150 and buy a 2W, "AA" (not bloody "AAA") battery powered Uniden. Or if you feel like splurging, buy the battery pack to go with it.
Here is direction taken off whereis.com.au for those of you that are from the coast
Start at PACIFIC HWY, UNDERWOOD
19.90 km 19 Mins
Continue along SOUTH EAST FWY, UNDERWOOD
4.18 km 3 Mins
Continue along GATEWAY MWY, EIGHT MILE PLAINS
424 m 1 Min
Continue along GATEWAY MWY [RAMP], EIGHT MILE PLAINS
159 m 1 Min
Continue along GATEWAY MWY, ROCHEDALE
12.55 km 10 Mins
Turn left at WYNNUM RD, TINGALPA
1.98 km 2 Mins
Turn left at RAMP > CREEK RD, CANNON HILL
237 m 1 Min
Finish CREEK RD, CANNON HILL
39.43 km 38 Mins
Course you can come yotis :)
I think the gold coast people need to decide on a meeting spot! Or I'll make one for you ;) Yatala Pies at 7:30 leaving at 7:45. There ya go, head up the freeway, take the gateway motorway exit, follow along until you get to the Wynnum Road exit. Turn left at the bottom onto Wynnum Road, follow along until you see a big shopping centre carpark on the left, turn left at the intersection with the BP and Red Rooster at opposite corners. Turn second left AFTER the first set of lights and that's the Bunnings carpark.
There you go, all done.
And that is different.... how?
:D
Hello all, I will be there. This is my first post on the forum (after many weeks of reading) so I don't really know anyone. I am happy to meet other owners etc. I have a completely stock Series 2 R33 GTS-T, so please be nice and don't give me too much stick...because when I say my car is stock I mean stock! Hope to see you all there.
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
