The Road to 200rwKw (R32)
G'day, I am interested to get the groups opinion on the best strategy for getting 200 rear wheel kilowatts out of an R32.
I use the car as a daily driver, so a nice fat torque range is highly desireable. Ideally i would like to see the power generated with the smallest amout of boost possible, focussing on keeping everything flowing as freely and cooly as possible rather than just getting a massive turbo and running like 20psi through a shitty small intercooler. A massive front mount intercooler is going to be my first step after the usual exhaust and intake mods.
Also, what sort of performance would 200rwKw provide? What sort of 1/4 mile and 0-100 times would be expected?
Cheers!
https://www.sau.com.au/forums/topic/6155-the-road-to-200rwkw-r32/
Start with a big front mount, and a full 3'' exhaust and a bigger fuel pump. if you are concerned about reliability i would get a HKS 2530 turbo or similar will easily produce that power at low boost whereas VG30 will need more boost and be unreliable.
People have different opinions on the injectors some saying that they will get 220rwkw with only more pressure but im doubtful, you will probably need something bigger. Then you will just need a remap of the computer.
If you up the car properly i would be possible to run mid-low 13's but many people have trouble with traction.
-Bigger Fuel Pump
-Large FMIC
-Aftermarket Turbo/Highflowed VG30 or RB25 Turb
-High Impedance Bigger Injectors
-Filter and Enclosure
-ECU Tuned
-AVC-R and up the boost or just use a bleed valve to run a little more boost... say 14 to 16psi
-Full exhaust
-Aftermarket AFM
Should do the trick...
may want to also upgrade the brakes....
I'd suggest a GT2530/GT2540 and a decent front mount cooler. You'll also need a big fuel pump and a fuel regulator as you'll be pushing those injectors. Bit of dyno tuning and you should see up to 220rwkw.
That will be the most friendly sort of setup, you could even play with the plenum and adapt a forward facing throttle body to remove the crossover pipe. Don't mess with a turbo any smaller, if you wanted something bigger (turbo), you'll notice it is alot less suited to what you want.
Performance depends alot on your ability as a driver to put it down, and your rear end setup; tyres suspension and so forth. You'd be looking to run low 13s with that sort of power, perhaps even sneak into the 12s.
Guest nismogtsx
Do what i did... Simple
T3/4
550cc HKS injectors
Bosch 700HP fuel pump
7/16" fuel lines
Nissan Patrol fuel filter
Pod air filter
Nizmo 300zx AFM
S-AFC
Mines ECU
Twin plate clutch w/nizmo preasure plate
Mines cams
Head work to the value of $2500
Tomei valve train
Tomei valve springs
700x360x77mm FMIC
Custom plenium
R32 GTR throttle body
HKS adj Cam gears
Upgraded brakes (cause u need to stop)
Thats about it... but you need a good 12-15 grand, I dont remember how much i have spent... But im gonna run a high 12 second quarter hopefully... My 0-100 is a high 4 seconds... I have cranked out 247rwkw's on the dyno the other day... But twisted the clutch... So im now getting the twin plate done ATM....
I want to hit the 300rwkw mark... I have all the parts in my garage for the next step... I bought a Tomei 2.4litre stroker kit and have all the bits ready... I have bought a spare NICS red block and am starting to build it up from there... So then ill be getting a large Trust or HKS turbo to feed this new monster and will be devestating all at next years jamboree.... (Fingers Crossed)
T3/4
550cc HKS injectors
7/16" fuel lines
Pod air filter
Nizmo 300zx AFM
S-AFC
Mines ECU
Mines cams
Tomei valve train
Tomei valve springs
700x360x77mm FMIC
Custom plenium
HKS adj Cam gears
fark! is this on you r31? u should see 300+rwkw with all that stuff on.
Guest nismogtsx
I went to Asian auto spare and stole a throttle body off an RB26dett that allready had a custom plenium (stole = found it before u did and i payed for it)... Its not a standard part... Sorry i should have explained it better....
And yes its in the R31...
And yes we expect some big power once we sort of the ECU... As we have had lots of trouble with the Mines ECU... Cause Chip Torque cant work on the other mods i have done... So we are thinking about either a Wolf 3D (min), a standard ECU chiped to the max (probably what we will do, mixed with some Apexi help in the way of a S-AFC) or Microtec (if i win the lotto soon)....
But yes i should look at well and truelly over the 300rwkw's mark... However i am running the car at 12psi max now as i want to achieve the power on minimal boost and dont want a time bomb motor... Understand???
It all depends on what you want to do.
I personally would go for a small turbo that could run a lot of boost (say 1.2 bar) and develop full boost at less than 4000rpm. Most of my driving is on the open road and on the twisties, a big laggy turbo IS A PAIN IN THE ARSE!
Injectors? Er.. I've been meaning to try fitting RB25DET injectors to an RB20DET .. but cant do much until someone lends me a set of them with the fuel rail. Im sure it will actually fit. Has anyone else tried this? 6x370cc's with a bit more fuel pressure and a good fuel pump should do the trick. I think GTR ones are a little on the big side.
SOme form of aftermarket ECU would be a good idea too.
Provided everythin is tuned right, high boost shouldnt be too much of a problem.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
