chaning your spedo dials on your dash to blue ones
Dragon18
 Share
hay guys i wanted to know if any of you have changed your orignal spedo dials to the ones that glow in the dark
is it hard to do and do you have to take your hole dash off
iam asking if any one done it in a 180sx but iam preety sure its all the same
so let me know -(
Originally posted by Black33
I did mine a long time ago as well and just REMEMBER TO BE CAREFUL WHEN TAKING OFF THE NEEDLES.
It is expensive and a real headache to get your gauges recalibrated - pay the little extra to get it fitted by a professsional
man not another thing i got on my car that u have 2!:)
when did u get yours?
I got mine done just after buying the car (about 15months ago), before I even joined SAU or SDU so I couldn't have copied you :)
I had to suffer with stuffed gauges for a little while and then had them re-calibrated. I only properly fixed my tacho recently when I replaced it 'cos it was un repairable after I had stuffed in when trying to put the faces on:lol:
luckly grim did hes first so when we did mine we knew what mistakes not to make again. Grim broke the springs on the tacho when removing it on his!
My tach is prob like 200rpm off comparing it to the reading from the s-afc.
how much one of these sets of ricey dials cost?
I actually wonder if anyone made 'em in red background with white letterings.... instead of white background....
they dont come in red as it would be 2 hard to read at night!
Mine go from blue to green and 5 shades in between and cost me $220 from Jetspeed.
dragon
emply your pm box i cant reply to your pm
cool i empyed it hahaha
ok i was worried about the calibration you talked about and worrying about my revs spedo and the rest going off?
when you say fitted by a professinal i dont mind doing that but who do i goto ?
i ask Garry's car audio if they can do it they said fine. i was going to do em both when i install my system but iam not sure i want some one to know what there doing and get it right the first time?
if you change it do you have to recalibrate it?
and if so where are these professinals in melbourne i dont mind spending that lil bit more to get it done proberly i saw one in unique auto sport site
but its only blue i think and one of you guys said you got one that changes colours or somthing where did you get it from
web site?? etc =)
thanks for your support guys =)
Originally posted by doxximus
rakis on unique autosports that one is blue and green, those are the only colours u can get (i think)
Theres a switch from blue to green and a brightness switch!
The green looks poxy anyway!
If you take it off carefully and mark all the points after u take the little plastic stoppers off and place the needles back exactly the same way you shouldnt have any problems!
As for Garys Car Audio doing it, check that they have done it before, as if they *** up your dash, u r gonna have to go buy another 1 like 1 of my friends did after the place he took it to stuffed his speedo up.
If the installer stuffed up, shouldn't they be responsible to replace ur speedo?
If it's so risky, would it be better to buy a cluster set ready to plug in, but that would cost heaps I suppose...
I would offer to help you install it dragon but I'm not in Melbourne anymore...
I installed mine and inasnt's with no problems at all, it's not that hard
If you read the article I wrote about it on my website then you shouldn't have any problems.
Originally posted by Dragon18
You guys know any one who actually knows how to do this stuff?
ro some where i can take it
i dont mind paying abit for it to be done proberly??
any help guys in melbourne =)
There is a place in dande that can do it for $50 but i dont know the name!
OOHSAM told me about it, but hes a useless prick! try and get in contact with him on 0421341981
 Share
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
