Here is a pic, all in very good condition and includes wiring harness and plug to the display and the wiring to the loom, dont have ny wiring instructions now but any auto elec/audio installer could tell you i would say, not neg on price yet, and wont send COD, direct deposit only, thanks everyone
OK scanner file is 24mb... damn its a good scanner...
Anyways here it is:
Red wire = 12+ constant
Blue wire = IG2 output (12+ on)
Green wire = IG1 output (12+ acc)
Gray wire = hand brake light (not nessary)
Black wire = ground
White wire = O2 sensor (refer to ECU dia in your car to find out where this goes, must solder this connection)
Thats it....
Thanks for the wiring Col
The timer is sold
Roy13 the reason i wont send cod is that i have no gaurantee you will pic the item up, then it will cost me money to get it back, i have a good rep on the forum and havent ripped anyone sorry if you dont understand
