Hi ppls,
Since I have had my RB30DET built up with a clearance checked RB25DET oil pump, I have noticed oil pressure is rather high. Not so much when warm on idle & cruise but mainly with high rev's (warm) & when stone cold.
I am aware the stock guage is a little dodgy but mine does appear to be consistant.
When cold & idling the guage reads spot on 8kg/cm2 (113psi), once driving & cold the guage will rise up to around 8.3kg/cm2 (118psi).
Once warm the guage reads 2kg/cm2 (28psi) on idle, 4.2kg/cm2 (60psi) on cruise (~3000rpm) and 6.5kg/cm2 (90psi) when reving hard (up to 7000rpm).
The 118psi seems extremely high... almost excessive.
The RB20DET never had such a high reading, at most it was 6kg/cm2 when cold with similiar pressures when warm on idle and cruise with the reving hard pressure up around 5kg/cm2.
Is this pressure excessive? I'm thinking maybe the oil filter by pass ball and spring isn't working correctly, I have heard the RB30's do have a high oil pressure when cold + being the motor has been setup with nice tight clearances (blueprinted) this could explain a few things.. MAYBE!! :P
The initial start of the fresh rb30det I crapped my self as oil pressure was up slightly over 8.5kg/cm2 (possible 20w50 running in oil??), I killed the engine instantly and rang my tuner. He didn't appear to be too concerned.
The motor is running well with now 6,000km's under its belt. No funny noises and the piston slap when cold has now settled.
The first 500km's there was no piston slap then it slowly began to appear, very quietly. Now it can be heard when standing next to the car however it is so quiet you would not really know what it was. My old man didn't even notice it and didn't know what noise I was talking about so it is a real light piston slap that totally dissapears once the oil pressure has dropped hence the car is up to operating temp.
I have actually grown quite fond of the slight piston slap noise. :)
Post your oil pressures people.. I am especially interested in those that have a RB25DET oil pump.
https://www.sau.com.au/forums/topic/61573-whats-your-oil-pressure/
I noticed a definate drop in oil pressure with the lighter 10w30 over the running in 20w50.
Not much though.. Maybe 0.3kg/cm2.
The most important difference between the running in 20w50 & motul 10w30 is when I put it on the dyno around 1000km's the running in oil appeared to thin out really easy when given a few power runs. The motul doesn't. Consistant oil pressure with the motul. Maybe this is why they state on the bottle of running in oil not to put the motor under high load. :P
When I go synth I have a bottle of 8100 5w40 here that will be in for 1000km's then I will be dropping in some 15w40 Motul 300v as I have heard of good results on the RB's, apparently it helps quieten down the top end and any piston slap some how, running the 15w40 over the 10w40 that is.
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
