Got a lend of dads work camera today ;) So good to actually get NICE photos compared to my dam mobile! Anyways I couldnt help myself & chopped my car to perfection if i may say so myself haha.
Anyways i thought I'd post the original, the edited, & the specific edited areas photos so people can try the same things & chop them on their car to see how much it can improve a photo *just like FHM making a woman’s breasts bigger for the magazines :)*
So here they are.
Original
Chopped
Guideline to editing
1. Lower your baby to a level so impractical you'll get stuck on a speed hump.
2. Enlarge them rims. The bigger the better they say *but not tooooooooo big* I did them 10% larger
3. Get that indicator light White instead of Orange, Ties in with the car now :P
4. A Shaven haven always gets restecp so to get that we'll shave off our door handle & petrol cap panel.
5. When you've lowered your car you might have taken away some of the shaddow around the wheel arch so I've added a discreet shadow to make things look normal again.
6. Well i simply dont like the grey/black stripe on the back of the skyline so i've made it white now.
Now to fully exploit the situation make sure *if you can* edit the image @ 300dpi so you can send it into your local car magazine *eg HOT4s* & knock their socks off with your now fully sick ride!
Cheers, :)
Hehehe it looks good aye :( It's ES15 Tint. When I went to get tinting there was pretty much the option of SP or ES tint *seeing I just wanted a dark tint*. SP is like straight black, & SP 05 is the darkest you'll get *the lower the number the darker*. The guy was recommending paying like a little bit more *only like 40$* & get the ES which was the top of the line Executive tint or something? lol. He said you wana stand out of the crowd with something different, & he showed me some pics of cars with that tint :P
Anyway I got it & It's really reflective. @ Night time it's nice & black and during the day a reflective lightish blue / black. Depends what’s reflecting off it. When i get home I can post some more pics of the tint & reflections if your interested?
  • 1 month later...
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
