  • Replies 74
114:1 afr's....damn smooth your runnin rich :(....man that sucks, your a little over the limit. Are you going to contest it...i know its pretty hard to get done for that due to the precise instructions on how theyre supposed to test. Such as the open area rule etc....hope it all works out, if not do a josh and change the rego to a different name lmao :D
If it pulled 114db ..
a) there is something funny going on.. and they ****ed up the test procedure..
B) you installed a straight pipe recently and/or jet engine.
Mine old R33 pulled 90db.. and my car wasn't loud, but you could hear it. Every 3db is double the loudness.
nah thats not all that unusual. I remeber when josh had the porsche tested it was up around that and i mean it was loud but not rediculous.
a) I said to the cop that the hand held tests werent accurate and he admitted that. So I take the result with a grain of salt. :D
B) correct, has been for awhile now.
If tested properly under normal conditions I would say it would be less... give or take?
Also, he asked why my rear bar was badly burnt... I had no idea why... exhausts are hot I guess :(
    • Nah. There's not shit tonnes of pressure in there. Just drill with a 1.5mm drill or something equally tiny. When the drill goes all the way through thee gas will start to come out, but with such tiny path through the flutes of the drill bit, it won't be at all dangerous. You can be as paranoid as you like from then on. I'd just pull the drill out while keeping my face out of the line of fire. But then, I spend half my time looking into pressurised furnaces. So my risk acceptance is somewhat higher than most!
    • Been needing a new clutch for a while, but holding off because of life tingz and adulting. But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799). Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them). Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
    • It was the pressure I was worried about. @GTSBoy does drilling them pose any problems?
    • yep just a JIC vs ISO insulator height. old coils are for JIC, new coils are for ISO
    • no just don't want the one I have atm. It's too stock and pristine to mod. Wanna buy a 0.34 Skyline that I can put the remaining 0.66 skyline parts on to make 1 skyline.
