Discrimination?
strutto
 Share
  • Replies 74
114:1 afr's....damn smooth your runnin rich :(....man that sucks, your a little over the limit. Are you going to contest it...i know its pretty hard to get done for that due to the precise instructions on how theyre supposed to test. Such as the open area rule etc....hope it all works out, if not do a josh and change the rego to a different name lmao :D
If it pulled 114db ..
a) there is something funny going on.. and they ****ed up the test procedure..
B) you installed a straight pipe recently and/or jet engine.
Mine old R33 pulled 90db.. and my car wasn't loud, but you could hear it. Every 3db is double the loudness.
nah thats not all that unusual. I remeber when josh had the porsche tested it was up around that and i mean it was loud but not rediculous.
a) I said to the cop that the hand held tests werent accurate and he admitted that. So I take the result with a grain of salt. :D
B) correct, has been for awhile now.
If tested properly under normal conditions I would say it would be less... give or take?
Also, he asked why my rear bar was badly burnt... I had no idea why... exhausts are hot I guess :(
 Share
    • This is a simple swap when you reuse the RB20 loom and auxiliaries. I run a standalone, but if I remember right, using the RB25 ecu you only have 2 injectors to inverse.  There are many DIY's on this subject online, including this forum.
    • Surprisingly the D6000 is only $1999, I'm waiting for the BF/CM sales, and hoping to get one cheaper. D4000 is well priced, still outperforms the 13" SVS PB-3000 and is like 1/2 the price at $1699 RRP. I do watch a fair amount of movies, and listen to EDM, jazz, symphonies, etc. so the lower notes from a subwoofer are always appreciated. The front 8" stage, just doesn't provide you with lively feeling, even though they are pretty bassy for a pair of large bookshelves. Then again, these days it's just playing Wiggles, Blippi and Ms Rachel, another reason the 3m wide cabinet exists, to hide all the audio gear behind it. They used to sit on a nice pair of stands, but as you know, they make good baby traps too.
    • Granted, which is a solid reason why I don't have one. My floorstanders are only -2 dB at 22 Hz.  So they're still working down to <20 Hz. Which is no doubt part of the reason why my receiver shits the bed! That Tonewinner would be about double the cost though, so it's not apples and apples. There aren't many AU$1300 subs (that you can buy prebuilt, I'm ignoring what can be achieved by DIYing) that compete.
    • -6dB at 22Hz isn't that great, watch the data from the D6000 from REW
    • I'll just leave this here. https://www.adelaidespeakers.com/subwoofers.html TL loading, big power. They sound awesome. This is what I would buy if I was going to try to take the bass away from my floorstanders. Just go with the 12".
