Rezz's Japan Forum Q + A Thread
  • Replies 201
As I have never done talk with female of foreigner,I'm interested in the bronze woman.
But Shan..actually Isn't the bronze woman of looks good?you think?
I am imagining the beauty considerably.hahahaha
Hahahaha!!! You like bronze women Akihito?
I like Ganguro!!! :cheers:
Yo Rezz, another question...
If some one asked for my address (aka my parents) to send me some stuff (a package).. Will this do?
Peter *****
Level 4, Apartment 404,
2-17-1 Negishi
Taito-Ku, Tokyo
Post code is 110-0003
Also my building doesnt have a door man or anything, so theres no way to get to the fourth floor (let alone inside) without a key. Will the mail man leave the package at the front door? Or will i end up having to pick it up from a post office somewhere? :S
Thx =)
Peter *****
2-17-1 Negishi
Taito-Ku, Tokyo
Thx =)
Good questions Poida... I was wondering when somebody would ask about this.
Firstly, the address above WILL get to your house, but you could make it easier for the postman by writing/typing:
Tokyo-to Taito-ku (Negishi-chou) 2-17-1-404
JAPAN 110-0003
** 'Negishi' sounds very local, you may not need to put this in the address but please verify with a Japanese aquaintance.
Secondly, the postman usually has access to the back of where all the mailboxes are (you may not be aware of it), so if the package can fit in the mailbox he'll leave it there, if not, he'll put a receipt in there which you can then take to your local post office and retrieve the package (you'll need ID for this - last time I got asked to produce my Gaikokujin Tourokusho or Foreigners registration card). I guess it's pretty obvious that packages aren't left at the front door.
mmm bronze women... I'm thinking you mean like brazilian women. I would choose a japanese girl over a bronze girl myself.
Hey rezz, isn't that addy in english? would the postman be able to read it being in romaji and stuff?
Yeah, it's in Romaji... Japanese postal workers can read Romanized Japanese place names no worries. In fact the address could probably written backwards and it wouldn't make any difference.
ブロンド
like in
(why they called "Life or Something Like It" "Blonde Life" I dunno... along with so many other english movies that come out in Japan with wierd titles)
or
ブロンズ
like in
あきひと、「ごめんね、お名前の漢字をしらない」あなたのSAUのメンバーの口座が変わったことがわかった。なぜ変わった?
Rezz
As I could not login at my office,change the username and passward.actually forgot passward.
And my name is あきひろ.not あきひと. Almost!!おしいー!!
Shan
Kanji is difficult right?
Troy
Sorry,I could not receive your call yesterday night.I was getting drunk and sleeping.
    • Well, if it wasn't a GTR I'd say that killing an RB is a perfect opportunity to put in a proper engine. In your case, proximity to Brabus and AMG V12s would be a no brainer for any RWD Skyline engine death event. In my case, because my car is my daily, anything that I do wrong that means I have to do it again is both an absolute pain in the arse (simply having to do it again), and also a doubling of the pain associated with having the car off the road to work on it. I would class a botched head gasket install as not being "engine death causing". More a case of "f**k it's still leaking!"
    • Yeah, this is more stuff like transmission/clutch R&R. Intake manifold R&R. It's not super complicated, but each step matters and you need to be careful and patient. I have heard stories for example of people not figuring out the super coppermix twin plate orientation and getting it wrong on assembly. Removing a cylinder head and putting it back in once it's machined isn't that hard, following torque sequence to install some cams isn't that hard either, but somehow I've seen a lot go wrong between here and there. Scraping off all gasket material isn't that hard either, but I've seen shops ruin heads by using a roloc disk that was too aggressive.
    • There is some shops in Germany that have quite a bit of experience with JDM performance 4-wheelers. I think if it actually comes down to it I'd let one of them do the head gasket. Killing an RB26 is too expensive a risk just to save some money by doing it yourself.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
