Well Ive started making a few posts and even threads on the forum here before putting up some info on myself and my new Stagea so here it goes..
A few of you might know me already, I used to own an Orange Toyota Starlet Glanza Turbo Replica (later model GT Starlet) that was featured in Fast fours a few months ago, heres some little shots of it, click on the link below if you wanna see some more on it. You might also know me because I run a few other car related sites such as the AU Starlet Club (owner/founder) http://www.austarletclub.com/ and also the Toowoomba Car Forum (owner/founder) http://www.toowoombacarforum.com/
http://www.austarletclub.com/lone/sell/index.html
Anyhoos I finally sold it and bought myself a Stagea, I was looking originally at a Chaser but the price of the Stagea and the features had me sold, I am a Toyota man but Nissan certainly made a good range of performance vehicles and I also like to own somethign different and Stagea won me, heres some details and photos on the car.. I bought the car stock as and have just recently added some of the new parts (exhaust, boost control etc.)
1998 Nissan Stagea
RB25DET Motor as standard
GTR AWD Driveline as standard
Full Black Leather Interior (photos to be added soon)
Full electrics including seats
Climate Control etc. etc.
BMC Panel Filter
3" Cat back exhaust
Apexi AVC-R Boost Controller
To be lowered soon :(
Im really loving the car and how well its responding to mods, I am hoping this weekend on one soon to run it down the 1/4 mile and see just how quick these things actually are..
Cant wait to see this section of the forum as Im certain it will with more and more coming into the country and seeing a lot more common knowledge on the cars over this side of Japan :)
https://www.sau.com.au/forums/topic/61604-my-new-stagea/
very very nice photos, nice example you have there. Mine is identical to yours down to the wheels. Had been thinking about colour matching my door rubber trim (typically they are black from factory), and wondered what it would look like. So thanks to your photos I can get an idea on a real example rather than doctor up some photos in photoshop.
https://www.sau.com.au/forums/topic/61604-my-new-stagea/#findComment-1163636
I just purchased my Stagea 12/98 model, Neo RB25DET last week from the Gold Coast and I too was looking at the Chaser as well but the price was too much compared to the Nissan. Took my new car for a spin to see what it was liked, left Gold Coast 0930 yesterday and arrived in Cairns 0630 this morning and shit it felt good but soon due for a couple of changes exhaust, fmic and some boost. Took a 97 model with cat back for a test drive before the Neo powered 98 and there is a noticeable difference between the 2 motors.
Really need to track down the fuse for the cig lighter tho :flamed:
https://www.sau.com.au/forums/topic/61604-my-new-stagea/#findComment-1184224
    • If you have a RB25DET NEO AWD motor, you will need this: https://www.hioctanedirect.com/ASR-RB26-RWD-Street-Comp-6.5L-Sump-Suit-R32/33/34-and-VL It is made for the AWD motor, but makes it fit a RWD setup and gives you a new pickup. Just one thing, the pickup sits quite forward, compared to a conventional RB25DET RWD motor. This may or may not have contributed to my previous AWD -> RWD shitting the bed at the track.
    • My car is also flex tuned. It's worth mentioning it (the LS1 ECU) has a 1D table for E85 addition and just uses the ethanol stoich part as the second point of reference. It also as a 3D timing map for Ethanol adjustment. You would think this isn't enough but it works pretty damn well. That said, I wouldn't want it in turbo application. It's like lifting non-natty, or taking meth. It gets you unrealistic results that break down more things going forward. If people used it to make the same amount of power they do on 98 then it'd be one thing. But people use it, crank it up to eleventy million PSI, it doesn't knock - but it pushes the point of failure to another, more expensive thing to break. Every time I see someone make 280kw on 98 and 350kw on E85 on the same equipment I just cry a bit and really wish they would just stay on 98 in that exact scenario. It's bad for you.
    • This is kind of what I was thinking but the temp sender wire and the two pressure switch wires run through the starter subharnes and I eliminated the two pressure switch wires completely.  @GTSBoy I have a can gauge with unusually bright warnings should the oil pressure fall so the factory light isn't needed. I need to dig out my wiring diagram and see if I can sort this out.
    • It's a valid point. And it is doable with the Nistune. But I'm not inclined to flex it the way Nistune does - certainly not on a Neo ECU. They're already pernickety enough to tune just one one fuel. And of course, I'm not that interested in putting in a Link or similar, on a daily. With the stock ECU, stock looking turbo, etc etc, I still stand a chance of surviving a run-in with the plod. Last time it went over the pits (which was for the transplant, for because of a run-in with the plod), the Nistuned ECU did not even raise an eyebrow. They want to see a stock ECU running the engine, and they are happy to see it do so without the check engine light** on. Never mind that the Nistune is necessary to make the stock ECU work in a different chassis without ABS, TCS, etc. **And they actually provoke the CEL to come on by disconnecting the AFM, to prove that the globe hasn't been pulled!
    • This is why you flex fuel it...
