Stagea Parts List
Lone
Series II Fog Lamp Bulb = H3 55W
They have an inner lense which is yellow
One of mine was already broken so I
broke the other one out. Because it's a
sealed unit you need to break the yellow
inner lense into small enough pieces to
fit them thru the globe oriface.
Viola! White 'fog lamps'.
Another place to look its a NZ site. ltc-powerpro exhaust store
here you go fellas. For those that have had a smash, heres a guideline for some repair costs :P
Hi if you could source a support assy-raidiator cor 625ooov710 at the price on this part list i will by 1 now if so please send me a pm and its done .
  • 1 month later...
Hi can anyone confirm part numbers for series 2 timing belt & water pump (NEO)? I think they are:
Timing belt: 13028M [full (?) part no. - 13028-5L327]
Water pump: 21010
Any help would be appreciated! Just want to make sure I order the right parts... I know these are around somewhere for S1 (indeed in the excellent SK timing belt replacement thread under the DIY sticky there is a part number for non-neo timing belt) but in case NEO is different I just want to be sure...
send me your vin i can check. series 1 are:
timing belt 13038-20P25
water pump 21010-21U26
also while you are there replace idler and tensioner bearings
13074-58S00
13070-5L300
timing belt and bearings are much cheaper aftermarket than from nissan.
13074-58S00
13070-5L300
Cool, I didn't know the idler and tensioner bearings were easily sourced/replaced. Yes pretty much a 100,000k service is what I'm after. Anyone know approximate cost of idler & tensioner bearings?
Cheers,
DaveB
OK Series 2 part numbers are:
Water Pump 21010-AA526
Timing Belt 13028-5L327
Tensioner 13070-5L300
Idler 13074-58S00
Not sure of the price of the bearings, haven't bought them for a year or 2. But they fail more often than timing belts so don't skip them. Nissan are very expensive for waterpump and the bearings.
Hey guys, having my 260rs dumped at the front has givem the lip at under the main front bar a total bashing really want to get it back to a nice condition again but having mine fixed is going to cost $450 - $500 which seems like a lot of moola was wondering if anyone can suggest where i could get a newy or if anyone knows a part number so i can try and source it specifically.
Cheers
  • 4 weeks later...
had a stagea nm-35 for a few weeks now an the windscreen motor somehow took on some water an totaly shat the thing to bits, any body selling a new one or know of someone/somewhere i could get one...
i got talking to a nissan parts dealer an he can get a new one in for 500
Hello
Im After a part number for 2002 M35 Stagea.
Rear crossmember.
It is an alloy frame that holds the diff and rear suspension.
Thanks for your help.
Murray
Hi Duncan
My Vin 6U90000NM35311957
Rear crossmember
I was lucky enough to buy the car (nice piece of gear) for a decent price, found two nice cracks in the cross member when checking brake pad life. The cracks are lateral between the top control arm mounting points. No idea how they occured. I've considered straped onto boat to hard.
Aggressive launching,
strapped onto a dyno,
anyway the seller is suppose to be having one sent out from Japan I've been waiting since 13/2. You shoud try waking up and thinking about going for a drive a not being able too. At least it is clean.
Just wanted to enquire abuot price and availability from Nissan Aust.
Murray
Hi Duncan
Rear crossmember
Murray
Murray
Sorry to hear that about your car. That aluminium sub frame looks so nice. Acording to my FAST software it says that is part number 55400 but no idea how to get a cost. Good luck.
Cheers
Andy
Andy, once you've got the part number in the fast list you need to hit f5 to bring up the full part number.
55400 is generic rear subframe
55400-AQ500 is the one for that car.
murray that is really wierd. subframe is normally bloody strong (although maybe less so if these have an ally one?) got any pics?
May get time tonight I'll take the wheels off and take some pics. Then try and post.
Yes I'm really at a loss as to how this component could crack.
Hoping to have it repaired soon
Murray
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
    • does anyone know the specs of the R35 master cylinder, rear ratio and knee point? the BM57 is a 0.4 rear ratio with a 435psi knee. I'm looking for someone with a much lower knee pressure. the piston area of the R35 brakes isnt that big so might not work for me but this is interesting.. the other option for me is a GU patrol master cylinder and booster and do the prop valve externally.
    • It sounds like by avoiding maintenance you may be doing more damage than a hypothetical guy in a workshop taking it for a spin. Not sure if you are just being paranoid or things are actually that bad in the US. Find a reputable shop not run by dickheads. Look for people that take pride in their work. Stick around for the day if you have to
