Series II Fog Lamp Bulb = H3 55W
They have an inner lense which is yellow
One of mine was already broken so I
broke the other one out. Because it's a
sealed unit you need to break the yellow
inner lense into small enough pieces to
fit them thru the globe oriface.
Viola! White 'fog lamps'.
Another place to look its a NZ site. ltc-powerpro exhaust store
here you go fellas. For those that have had a smash, heres a guideline for some repair costs :P
Hi if you could source a support assy-raidiator cor 625ooov710 at the price on this part list i will by 1 now if so please send me a pm and its done .
  • 1 month later...
Hi can anyone confirm part numbers for series 2 timing belt & water pump (NEO)? I think they are:
Timing belt: 13028M [full (?) part no. - 13028-5L327]
Water pump: 21010
Any help would be appreciated! Just want to make sure I order the right parts... I know these are around somewhere for S1 (indeed in the excellent SK timing belt replacement thread under the DIY sticky there is a part number for non-neo timing belt) but in case NEO is different I just want to be sure...
send me your vin i can check. series 1 are:
timing belt 13038-20P25
water pump 21010-21U26
also while you are there replace idler and tensioner bearings
13074-58S00
13070-5L300
timing belt and bearings are much cheaper aftermarket than from nissan.
13074-58S00
13070-5L300
Cool, I didn't know the idler and tensioner bearings were easily sourced/replaced. Yes pretty much a 100,000k service is what I'm after. Anyone know approximate cost of idler & tensioner bearings?
Cheers,
DaveB
OK Series 2 part numbers are:
Water Pump 21010-AA526
Timing Belt 13028-5L327
Tensioner 13070-5L300
Idler 13074-58S00
Not sure of the price of the bearings, haven't bought them for a year or 2. But they fail more often than timing belts so don't skip them. Nissan are very expensive for waterpump and the bearings.
Hey guys, having my 260rs dumped at the front has givem the lip at under the main front bar a total bashing really want to get it back to a nice condition again but having mine fixed is going to cost $450 - $500 which seems like a lot of moola was wondering if anyone can suggest where i could get a newy or if anyone knows a part number so i can try and source it specifically.
Cheers
  • 4 weeks later...
had a stagea nm-35 for a few weeks now an the windscreen motor somehow took on some water an totaly shat the thing to bits, any body selling a new one or know of someone/somewhere i could get one...
i got talking to a nissan parts dealer an he can get a new one in for 500
Hi Duncan
My Vin 6U90000NM35311957
Rear crossmember
I was lucky enough to buy the car (nice piece of gear) for a decent price, found two nice cracks in the cross member when checking brake pad life. The cracks are lateral between the top control arm mounting points. No idea how they occured. I've considered straped onto boat to hard.
Aggressive launching,
strapped onto a dyno,
anyway the seller is suppose to be having one sent out from Japan I've been waiting since 13/2. You shoud try waking up and thinking about going for a drive a not being able too. At least it is clean.
Just wanted to enquire abuot price and availability from Nissan Aust.
Thanks for your help
Murray
Hi Duncan
Rear crossmember
Murray
Murray
Sorry to hear that about your car. That aluminium sub frame looks so nice. Acording to my FAST software it says that is part number 55400 but no idea how to get a cost. Good luck.
Cheers
Andy
Andy, once you've got the part number in the fast list you need to hit f5 to bring up the full part number.
55400 is generic rear subframe
55400-AQ500 is the one for that car.
murray that is really wierd. subframe is normally bloody strong (although maybe less so if these have an ally one?) got any pics?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
    • Brakes definitely won't make him faster. They only slow you down. 😛
