I have an ARC airbox on my R32 GTR... Does the job but miss the induction note I used to get on m other cars. If I go to HKS pods and filters do you get an induction sound? If I do this I will be fabricating a shield around them to duct in the cold air etc as I realise the ARC is doing a good job.
Also foam or mesh .. different induction note?
Or maybe this is bollox and will sound the same.. lol
Anyone?
:flamer: Not all at once! I'm a newbie :Oops:
switching to a pod will give u a louder induction sound, hks foam filters work pretty well for this. Using a shield around them, might negate this though. most people don't bother with ducting as it wont really effect intake temps/airflow a whole heap.
(sorry, couldn't resist, your sig bought it on....)
i jus fittend an Apexi Pod on my S15.. get the induction sound as well as a lil Pshhhh lol... However with the HKS or TRUST Pods u will get a massive inductiuon sound as well as flutter- Pstttt chu chu chu... But with the mushroom filters it filters a less than the others...
Regardless of noise, check this out
http://mkiv.com/techarticles/filters_test/2/
May be of interest.
very interesting article.... *adds to bookmarks*
i find that my K&N has quite a loud induction sound for a turbo car....... its either that or my turbo is reaaaaaaaaaaaaly ****ed.... but anyways its loud ... :aroused:
good luck
Matt
  • 1 year later...
yeah, but with non-turbo, u dont get flutter!!
If i can be bothered, i'll record a sound file while sitting in car with my mp3 player
Thats because flutter is caused by the air going back into the turbo fins from the bov. Hence y u dont get flutter on atmo bovs either
i had the hks pod on my car which was loud and sounded mad, only problem was i didnt like the thin foam it had as it was being sucked in over time onto th afm ( when i had that still) so that worried me a bit and alot of guys i know have had the same...i changed it for a K&N and thats no "as" loud but louder than i thought for a K&N, plus i dont worry about the pod elements breaking off and going into the turbo
ben...
yes K&N = probably the best pod you can buy. very good filtering, long service life, good flow. having said that i must not be following my own advice as I have apexi pods on 2 of my cars (and all three I put on there).
Alot of people go with the K&N pods, and its a quality brand, there just a fair bit quieter than, mine for example. Its just a cheap branded one, DRIFT or something, but its insanely loud.. Still trying to decide if i like it or not. Oh and the K&N pods that some people choose, are just downright ugly :P
i reckon the stock air intake is as good with a panel filter when the car is making less than 300 awkws. im using a HKS one and it does make a little bit of noise.
keep myself trouble free...
Edited by frankxy
were you previous cars n/a? having a turbo in the way really quietens down the induction noise compared to other cars.
I didnt know u get a loud indcution sound of an NA skyline? I always thought that it was the turbo the increased the loudness?
Edited by shorty_01
People are talking about 2 different types of induciton sound here - On most turbo cars, the induction sound people talk about is the sound of the turbo.... not really induction noise, but its on the induction side so i guess it counts.
Proper induction noise sounds awesome. Go for a ride in an NA car with multiple throttle bodies and you'll hear it for sure... The vtec honda's have a lot of induction noise for a standard car... when the cam timing changes on them, they really scream.
The only turbo car i've heard with loud induction noise was i think leroy(?)'s R33 GTR video at autosalon where it made 600rwkw or so. When they loaded it up on the dyno out of its boost threshold.. mmmmmmmmmm
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
