rim / tyre size on cefiros
kursed
 Share
hey i'm thinking of getting 19's with the following tyre specs:
225/35/19
will they fit under the lowered cef easily? I should be able to have a test fit but just want to know if it's worth trying.
will they still be legal?
cheers!
Luke
FAT.
Got pics? :)
I'd say you need to roll your guards atleast. Probably spacers at the front. And a "fat" offset.
My rims are 18x7.5 (or 8.5) and the front needed 20mm spacers to fit (the guards are already rolled).
They wear 225/50/18 I believe. (Could be 235/45/18 can't remember).
I reckon I could fit 19's with 35 profile so if you want to test fit on a cefiro with spacers and rolled guards I volunteer mine (save you rolling your guards only to find you cant put the wheels on). I'd love to see my car with 19's (the 18's don't look big enough ehh heh so for a dumped look if I could I'd get 20's).
As for legality without engineering I don't know. I never was able to work out the proper thing (even after reading the RTA document about it) but... Duncan explains it pretty well here.
The actual RTA docs are here - http://www.rta.nsw.gov.au/registration/dow...si/vsi_dl1.html
And the wheel/tyre guide is here - http://www.rta.nsw.gov.au/registration/dow.../vsi09_rev4.pdf
Good luck :P
Whether the rims fit will depend highly on the offset and width of the rims.
Given the tyres you are planning on using, i'd guess they are 8 or 9 inch. If you get the correct offset, then they should fit fine with some guard rolling..
the rims are 7.5 wide, with either an offset of ET20 or ET42 - these are the manufacturers specs but the guy with the wheels hasn't checked - they were on an R31 skyline so does anyone know which offset it is likely to be?
cheers!
no pics yet cc :)
this is what i have gathered from rta site and another forum.
stock wheel size ...according to my cefiro (which has a wheel placard) ..is 15 x 6.5 wheels with 205 /65/ 15 tyres.
legally without a engineering certificate u can only go 1 inch wider and a max of 15 to 20 mm larger in total wheel and tyre diametre size......so u could have 18s on but lows profile tyres of 35 or 40 or something like that ....check it againt one of those tyre size calculators....this is this is one
the rta website says for enineering ....they can only go up to 2 inchs wider that the extra inch i think ...which would be another 3inchs to the width of the stock rim ......
thats how i read it anyway...
Tire Size Comparison
current stock wheels
Specification 205/65-15
Sidewall 5.2in
Radius 12.7in
Diameter 25.5in
Circumference 80.1in
new wheels
Specification 225/35-19
Sidewall 3.1in
Radius 12.6in
Diameter 25.2in
Circumference 79.2in
I recently got rims on mine with no spacers.
Front and rear have been rolled slightly
18 x 7.5 (offset +32) on front with 225/40/18
18 x 8.5 (offset +32) on rear with 255/35/18
I start to get the fronts rubbing on full lock, and not much room at the rear.
They seem to be a pretty perfect fit.
oOOo kursed is getting dubs on his virgin ceffy!
i have 18 x 7.5
post pics of the wheel, or type,
i want new wheels,
just so i can interchange them for how my pimp lean is feeling...
i want some mesh high polish steel with the lowrider gold spinner in the centre =) drooool
put it this way pimpdat you wouldn't wanna lower your car too much with 10 inch on the rear, especially with 9 inches on the front, but if you're going for the "pimmped out" look then they'd look quite porngraphic on a cefiro
i had 17x10 wheels on my cefiro for motorvation this weekend
they had a gtr offset(i have 5 stud conversion)
they was just tooooooooo wide on the rear and my guards are rolled slightly, i had to dial heaps of neg camber to get them to fit
but on the front it was fine the offset allowed for everything to clear and they only stuck out a little bit
so the offset is the most important thing
Also just to throw a spanner in the works... I think you need to make sure the wheels also clear your brakes, as I know my front ones without spacers, I cant even put the nuts on the wheel properly. But umm, 19s dude... Think about that, they arent really a practical size wheel.
dubs are 20's dude!
yeah i know! but 19's!!!! argh. spoof. well basically i found a set for a good price and i am doing a bit of cefiro group research, so these opinions are welcome. unfortunately they are not in nsw so i need to go somewhere that stocks the rims and trial fit them... i think tempe would have em. I may just end up with 18s but the wheel arches are so wide on the cef i think they will look like 17s
pimp dat those rims are fkn FATTER than kirstey alley after a pie eating contest.
good luck getting your ride lowered over those though.
I have 235/40/18 on mine heres a pic for your veiwing enjoyment - I just threw these on and didn't roll any guards, they don't scrub at all - but there is a possibility that it was done before I got the car.
these are the rims i thinking of getting. +5 and plus +6 offset, WTF does that mean i have no idea i am getting wide body front but dont know about the back. are these going to be hard to fit?
sorry for changing topic a bit kursed
man they are nice :D they are the ones i was going to get for my R33, GMAX do some here in Aust. but so far i haven't found a 4 stud option
 Share
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
