cross drilling and slotting will do a couple of things to a disk, a pro being that you'd be getting rid of heat quicker, and big con being that you are weakening the disks a LOT .. obviously the choice if yours but i dont think i'd like relying on weakened disks for my life !
So are you saying that any cross drilled disc are weak? or are the ones you buy already cross drilled/slotted made of a stronger material?
crossed drilled are meant to be weaker on the whole and many people have seen them crack after extensive use (not just on the track to i might add). Personally i would keep them standard and go buy some dba 4000 + get some better brake pads then the standards.
What is dba 4000 +?
I'm using some Motul Rb70 (I think it is) brake fluid and I got a set of Bendix Advance pads going into it. Do you think I'm going about it the right way so far?
And would this brake set up be suitable for some hard laps at a track?
Just my experience so i'll share it
Bought my car runnning standard rotors and Bendix Ultimate pads. It was good on the road but under extreme conditions like Mt Bulladelah or Mq Pass they struggled.
The stock rotors where to worn to skim again so i needed to replace them. Standard replacement cost the same as EBC half drilled and slotted of the same size so i got em.
Matched with EBC red stuff in the front and green stuff in the back plus 5.1 race/rally fluid i hit the Eastern Creek with high expectations.
It never had alot of bite under hard breaking or feel but i was still running ABS. After 5 laps the breaking distance increased slightly but the car became unstable breaking into turn 2 and the hairpin.
After driving Duncans 32 with big rotors and a pad combo put together by RACE BRAKES in Sydney i was even more dissapointed with my set up. The difference was unbelieveable.
Returned the car to the workshop that set it up. Rear brakes at some stage had been on fire. Fronts had not been up to temp in time and caused rears to over heat which then put all the effort back to the front whilst the rears kept cooking and doing little breaking.
Changed to Endless street spec "Y"pads in the front and standard Bendix Advance in the rear for street driving.
After hard breaking massive shuddering was occuring.
The hotter they got the worse it got.
Had the disc skimmed and it was fine until i got them really hot again at Wakefield and they again shuddered.
Examined the rotors and noticed tiny 3mm-5mmcurved hairline cracks all the way around the face of the rotors.
Had them replace with DBA slotted rotors and Bendix ultimate pads.
So far so good.
The cross drilling weakens the surface of the disk more than slotting.
If you read through the DBA website they don't recommend the Cross Drilled for circuit.
The problem is that when they cool down, the area around the drill cools at a different rate to the rest of the disk as there is more surface area to radiate heat.
That area cools faster and hairline cracks form.
I had an 88 VN Commodore with Slotted and Cross Drilled on front and rear and the fronts had cracks all over them.
BASS OUT
Bugger, Duncans stealing my car and letting lunatics from the deep south drive my car again:)
Funny enough im about 1wk away from finishing another reco of my brake setup with now Comp 9 pads...see Here for the Tutorial i just posted.
Drifto...did you get the seat in ok... ive finally got my rails spot on now, so if you need piccies or help let me know:thumbsup:
I'm coming up to a pad change soon (Putting in some Bendix Advances) and naturally I'm going to get the guys to machine the disc, is it possible to cross drill or slot standard disks?
Yes, they can be slotted (I'm tracking down the name of a guy who can do them for you). What I have found is that slotted rotors are virtually "self-cleaning", ie if you glaze up the pads and rotors, the slots clean the pads, and the clean pads clean the disk.
Meantime, I'd be fitting Ultimates, rather than Advances. My reading of the Bendix info is that they are for a Joe Average driver in a family sedan; they are not a performance pad (someone correct me?).
While you can spend a fortune on DBA's, for a little over $500 you can get the RDA stuff with slotted fronts. Irecommend the Racebrakes products. RB74 front and Comp 2 rear with motul DOT 5.1 fluid. Haven't had a brake fade yet.
SH?T
Sorry Troy, i meant you
How's Duncan anyway i don't think i've even met him.
The seat is megga!
Got Sparco rails to fit up perfect, I now have a good two inches head clearance and my arms can steer instead of trying to stop me falling out of the seat. Although getting in and out is an art form.
just that i would not personally like to drill standard rotors and rely on them to save my life when i need it ..
however, i'm all for installing some drilled and slotted rotors that have been designed for the job ..
haha I did what? Dorifto we must have crossed paths one day but I'm not sure, where you at OP on Sat? Kel and I were there in the 350z
Anyway....some people have had trouble with cracked cross drilled rotors so probably give them a miss.
You can most certainly have your rotors slotted though, this shouldnt have an impact on strength if done properly....DBA 4000 for instance start life as a blank rotor and have the slots machined into them later. check out www.dba.com.au
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
