  • Replies 80
U mean 90w for lowbeam?
I was pulled over by police for running them in my first car.
I was told to but back the origonal spec ones.
I think I was running 90/110 standard they were 45/55.
It also damages the reflective bit of the light after a while as it gets too hot and starts to peel.
Geeze,
I just got my r33 1 mth ago...first the left high beam went, now the left lowbeam is also gone! bloody.........
The previous owner had changed all the bulbs to Philips Enon 6000K. Dun ask me what they are, I just know they are good...well, until today...cos I dun have any beams on the left. Kinda sux.....
Help Anyone? I have read the whole thread, but no one can tell me how to fix it step by step.
is there seperate relays for left and right headlights ???
if so is it possible to join the two switch wires up which turn the relay on. that way wen u turn the knob on for the lights and there is bad contact, u still get both the relays goin on ??
Yep.. and Yep..
Thats what I did.
I mentioned it earlier on in this thread I think.
I pulled the dash switch out then soldered them both together at the end.. Or did I use a wire to join them.. It was a loooong time ago I did this mod. 2years to be exact. :D
Still working fine. :thumbsup:
So pull the switch out and bridge the two roll switches together.
  • 3 weeks later...
  • 2 months later...
as already mentioned, if you can tap the switch and the lights flicker on turn on temporarily, then its most likely the little plastic bits which push the contacts open and closed in the light switch. its very easy to spot them once you open the switch, they are in a line of 3 and are spring loaded. The one that has melted (either just cus nissan miscalculated current draw with age/ higher wattage bulbs used/ or accessories being run from the light circuit ie gauges) is pretty obvious to see, what i did for a temporary measure was to trim the melted bits off as it tends to mushroom at the top, then grabbed the spring and stretched it out a bit more to make up for the part that melted, then reassembled it and checked continuity at the plug. Sure this solution isnt long term if your setup remains identicle, but it is free :( and the switch is not hard at all to take apart and reassemble. just wish id taken fotos for you lot.
  • 8 months later...
Bringing up an old thread, as it just saved my ass quite a few dollars!
Everything is spot on... the switch was the cause of one of my headlights being out. Just took it out and gave it a good cleaning, played with the springs a bit, and Bob's ya uncle, all is sweet now!!!! Cheerio for everyone that posted here :D
Now to find a thread to fix my faulty climate control lol :headspin:
  • 5 months later...
  • 3 weeks later...
well I have this issue now ;)
the right globe sometimes doesn't work, and the left I think blew last night!
hmmmm
I might try cubes trick! so for the R32 GTR a H1 globe is the one needed for the projector style low beam ? correct?
Apparently it's either H1 or H3 depending upon the car. From what I've read there doesn't seem to be any reason/correlation between model and bulb.
At the risk of stating the obvious, have you swapped bulbs between headlights to check it's not the globe?
Cubes' trick seems like the goods, but if it dies you'll lose both headlights. I tried buttondownpsycho's trick and it worked but I was messing around with the headlights and highbeam switches and managed to melt another little pot.
Used switches are under $50 from JustJap.
haha I didnt know this was a big issue with nissans Far out Hey as well as the head lights does anybody get the sticking Indicator I have to fiddle with the Hazzeds to fix it :s dont know WTF is with that. I think they must be dodgy Wireing or maybe there is a water Prob only seems to happen on Rainy days or very cold morning when there is Due.
Can anyone confirm that R32 headlights do not run relays?
For what it's worth, when I took my car to an autoelec with the headlight problem, he suggested putting in a relay, from the working headlight, to fix it.
*shrug*
  • 6 months later...
I ahd the same problem except was right side , replaced switch and problem solved :P
Now 1yr later has started again , mechanic's had been checking electrical problem {turns out to be afm again} and since then right headlight playing up again >_< This time I think it may be the relay {getting old }
For the rest of you though, I would suggest you track down a spare light switch and give that a go . As said above should only be $50. :sorcerer:
  • 4 months later...
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
