you won't believe it .... when I said "it works a treat" ... I found that was only in the garage ;)
as soon as I drove outside the reception was shithouse!
heheh ... how can I make the reception better?
Can I wire a whole new wire from the actual aerial in the glass or is it too hard?
https://www.sau.com.au/forums/topic/6168-aerial-connector/#findComment-94170
Guest GR33DyMANGO
... why dont u just put a satelite dish on the roof? im sure that'll 'work a treat.'
all u'd need to do to get to the aerial would be to wire it off the new connector u just made. maybe you could run wire from there to a mobile phone aerial on the outside of your car. that way it'd look good at the same time... well maybe???
https://www.sau.com.au/forums/topic/6168-aerial-connector/#findComment-94457
my car came with a double-din head unit that got great radio recpetion.. after putting in my previous deck, the radio reception is all crackly and has static... so much for being an expensive deck huh?
If you DO find a solution James let me know hey... im in the same boat.. :(
https://www.sau.com.au/forums/topic/6168-aerial-connector/#findComment-94478
If you DO find a solution James let me know hey... im in the same boat.. :cool:
will do mate.
I'll try playing with the wiring a little :)
https://www.sau.com.au/forums/topic/6168-aerial-connector/#findComment-95227
Originally posted by riggaP
Does the aerial come up when the radio is turned on??? If I doesnt this is the cause of you problem. You may have to reconnect the other wire which signals the auto aerial... Its the only thing I can think of...
rigga, my car doesnt have an aerial that extends :)
it's just one of those aerials that's in the glass.
the only thing i could think of was that the metal in the garage construction was boosting the signal.
which means the car's aerial is probably shit :cool:
https://www.sau.com.au/forums/topic/6168-aerial-connector/#findComment-95229
JiMiH,
If your aerial plug has two pins, you must have 2 aerials. Skyline factory headunits use a dual diversity system for radio reception. When you wire your new plug, make sure you connect to the extendable main aerial (the thicker of the 2 co-axial wires) and NOT the sub aerial in the glass. The SUB aerial in the glass is no good for FM, which is why you're getting crappy reception. If you don't have an extendable main aerial (either auto or manual), I suggest you install one to improve reception. Also, make sure all connections are nice and secure, preferably soldered.
Cheers.
https://www.sau.com.au/forums/topic/6168-aerial-connector/#findComment-98146
hahahhahahahahhahaha good one :)
jimi, youll need to buy a connector (which youve already done) and take it somewhere to get it joined to the wires professionally. the reason your reception is shit, is beacuse youve got shitty contacts from the wire to the outlet. if you want a good result take it to an auto electrician or car audio place, they wont charge more than an hours labour ($50ish max)
https://www.sau.com.au/forums/topic/6168-aerial-connector/#findComment-100504
  • 3 weeks later...
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
