Hi all,
R32 gtr box with transfer, excellent condition: $1200.00
Celica GT4 manual front cut: $2200.00
New container arriving, need the space.
Cheers,
Ken
PM for pics.
https://www.sau.com.au/forums/topic/61682-r32-gtr-gbox-and-celica-gt4-cut/
details of celica cut please... 3SGTE engine specs, turbo specs, mods, parts included in cut, is the cut dressed or undressed etc. Also are you willing to pallet it to accomodate shipping to melbourne?
Hey Shan,
The cut is standard. Includes everything. It has a set of lights on it and the bonnet (bonnet has a dent). can supply doors, rear gate, bar, tail lights, diff for a small extra charge. The cut has 114000kms and has been started in Aus. Can ship to melb on a pallet - no problems. Buyer pays freight.
Cheers,
Ken
Oh - 3sgte, 2.0ltr twin cam turbo running the standard CT26 turbo. Put one in my mates aus delivered celica and just ran it fwd, went very well - easy conversion.
Ken
Ahh, its to go into an AE86 possibly. Currently leaning towards a CA18DET, but if I can get a 3SGTE and T04E for a good price then I'll put that in. Engine is awesome for lowend torque.
Can you get me a quote for pallet shipping? I prefer to use Toll or someone.
The are great engines. Can you pm me your delivery addy so i can get an accurate quote. will you require the rear diff etc?
Ken
won't be needing a rear diff, don't think so anyways.
Postcode 3086, VIC, if you need any more detail than that then I'll PM it to you.
... Is it sold?
Which GT-4 3SGTE is it exactly?
Please contact me if it is still available email/MSN :  jerdiv  ayt  hotmail.com
Still available. It is a full front cut from an ST185 celica GT4.
Will email you.
Ken
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
    • I must preface my comments with a general expression of ignorance. I have no specific knowledge of these NA automtaic things. I can only assume that the "steering wheel button" is for enabling the tiptronic controls. Wierd that it would even need/want a button for that... But anyway.... Was the car previously tiptronic? Did you put a new cluster in as part of all this?
    • Regardless, it doesn't seem wise especially on RBs to actually chase MBT. Timing scatter is the big one on stock CAS, even if that's fixed overshoot is worse than undershoot.
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
