  • Replies 59
hahahahaa lozzle drunk at 940am this is confirmed :P
hahahha
silwa v SAU volley ball comp.. anyone up.. :confused:
and what sport we playing? anyone layin down the law and saying which one we gonna do? :uh-huh:
hahahha
rules?
The governing body for the DOCS Olympic Volleyball shall be the U.S. Volleyball Association except as noted below:
  1. All opening rounds shall be round robin
    • Two games shall be played in pool play against each opponent
    • Teams not scheduled to play need to be available to work
[*]All games will be to 21 points, unless otherwise stated (rally scoring)
Playoffs will be best two (2) out of three (3) to win, unless otherwise stated
Triples games will be played to 15 (fifteen) points (rally scoring)
[*]To break a tie in a pool/bracket there will be one game to 21 points (rally scoring)
[*]The winner of the loser's bracket will receive third place.
[*]Mixed team play must have a minimum of two men and two women on the court at all times
[*]A team may have maximum of twelve players on its roster
FOLLOWING USA VOLLEYBALL RULES EXCEPT WHERE STATED
RULES OF PLAY
  1. THE SERVE: The server shall have 8 seconds after the referee sounds the readiness-to-serve whistle to hit the ball for service. The serve is to be made from anywhere behind the endline. The server may move freely within the service zone. At the moment of the service hit or takeoff for a jump service, the server must be completely in the service zone and not touching the court (end line included) or the playing surface outside the zone. After the service, the player may step or land outside the zone including the court. The server must contact the ball within 8 seconds after the first referee whistles for service.
  2. ROTATION: The team which receives the ball for service shall rotate one position clockwise before serving.
  3. SCREENING: The players of the serving team must not, through screening (moving or by position) prevent their opponents from watching the server or the trajectory of the ball. Screening is a fault.
  4. CONTACT WITH THE BALL: Each team is allowed 3 successive contacts with the ball except as noted in the Blocking Rule.
  5. CONTACT OF THE BALL WITH THE BODY: The ball may be hit with any part of the body.
  6. SUCCESSIVE CONTACTS: Players may have successive contacts of the ball during blocking and during a single attempt to make the first team hit of a ball coming from the opponents, even if the ball is blocked, provided the ball is not held
  7. HELD BALL: When the ball visibly comes to rest momentarily (in the hands or arms of a player). The ball must be hit in such a manner that it rebounds cleanly after contact. Scooping, lifting, pushing or carrying is a form of holding. A ball clearly hit with one or both hands from a position below the ball is considered a good play.
  8. SIMULTANEOUS CONTACT BY OPPONENTS: If two opponents simultaneously contact the ball and it remains in play, the team receiving the ball is entitled to another three hits. If such a ball goes "out," it is the fault of the team on the opposite side. A joust occurs when players of opposing teams cause the ball to come to rest above the net through simultaneous contact. A joust is not a fault, and play continues as if the contact were instantaneous (Rule 14.2.3).
  9. ATTACKING OVER OPPONENTS COURT: A player is not allowed to attack the ball on the opposite side of the net. When spiking, the follow through is allowed to cross the net without contacting the opponent.
  10. BLOCKING: Multiple contacts of the ball is legal during an attempt to block. Blocking a served ball is prohibited. Blocking is permitted after the ball is spiked, or intentionally directed toward the opponents side; or after the opponents allowable 3 hits; or after the opponents have hit the ball towards the net and no member of the attacking team is in a position to make a legal play on the ball; or if the ball is falling near the net and no member of the attacking team could reasonably make a play on the ball. Blocking a set ball before the spike is not allowable.
  11. PASSING AND RECEPTION OF THE BALL: Contact with the ball must be brief and instantaneous. Contact of the ball is permitted by the open hand, ball can not be lifted, held or thrown.
  12. PLAYER CONTACT WITH NET: Contact with the net either accidental or not is a fault. Hair is an exception. If the ball is hit into the net causing it to hit a player, such contact shall not be considered a fault.
  13. DEADBALL: The ball becomes a dead ball when: the ball touches outside an antenna, does not cross the net between antennas, strikes the floor or wall, contacts the ceiling or object attached to the ceiling which is 7 meters or more above the playing surface, a player commits a fault. A ball may be played off a lower ceiling or objects as long as it does not cross the net but is played on the same side. Net serve as long as ball passed between the antennas.
http://www.2005worldmasters.com/bcm/wmgame...3D?OpenDocument
thats it.. ur goin down *note to self dont wear any loose clothing that might come off to possibly distract opposition...*
ahahaha loose clothing is fine haha :)
anywhos i thought of a new sport................. we can commit to a full schedule of DnB gigs at heat, we will be getting a full body workout and sweat it out hardcore by the end of the night :D
so what ya think? :headspin:
for the slows who don't get it............. I'M JOKING
adrian ;)
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
