  • Replies 59
hahahahaa lozzle drunk at 940am this is confirmed :P
hahahha
silwa v SAU volley ball comp.. anyone up.. :confused:
and what sport we playing? anyone layin down the law and saying which one we gonna do? :uh-huh:
hahahha
rules?
The governing body for the DOCS Olympic Volleyball shall be the U.S. Volleyball Association except as noted below:
  1. All opening rounds shall be round robin
    • Two games shall be played in pool play against each opponent
    • Teams not scheduled to play need to be available to work
[*]All games will be to 21 points, unless otherwise stated (rally scoring)
Playoffs will be best two (2) out of three (3) to win, unless otherwise stated
Triples games will be played to 15 (fifteen) points (rally scoring)
[*]To break a tie in a pool/bracket there will be one game to 21 points (rally scoring)
[*]The winner of the loser's bracket will receive third place.
[*]Mixed team play must have a minimum of two men and two women on the court at all times
[*]A team may have maximum of twelve players on its roster
FOLLOWING USA VOLLEYBALL RULES EXCEPT WHERE STATED
RULES OF PLAY
  1. THE SERVE: The server shall have 8 seconds after the referee sounds the readiness-to-serve whistle to hit the ball for service. The serve is to be made from anywhere behind the endline. The server may move freely within the service zone. At the moment of the service hit or takeoff for a jump service, the server must be completely in the service zone and not touching the court (end line included) or the playing surface outside the zone. After the service, the player may step or land outside the zone including the court. The server must contact the ball within 8 seconds after the first referee whistles for service.
  2. ROTATION: The team which receives the ball for service shall rotate one position clockwise before serving.
  3. SCREENING: The players of the serving team must not, through screening (moving or by position) prevent their opponents from watching the server or the trajectory of the ball. Screening is a fault.
  4. CONTACT WITH THE BALL: Each team is allowed 3 successive contacts with the ball except as noted in the Blocking Rule.
  5. CONTACT OF THE BALL WITH THE BODY: The ball may be hit with any part of the body.
  6. SUCCESSIVE CONTACTS: Players may have successive contacts of the ball during blocking and during a single attempt to make the first team hit of a ball coming from the opponents, even if the ball is blocked, provided the ball is not held
  7. HELD BALL: When the ball visibly comes to rest momentarily (in the hands or arms of a player). The ball must be hit in such a manner that it rebounds cleanly after contact. Scooping, lifting, pushing or carrying is a form of holding. A ball clearly hit with one or both hands from a position below the ball is considered a good play.
  8. SIMULTANEOUS CONTACT BY OPPONENTS: If two opponents simultaneously contact the ball and it remains in play, the team receiving the ball is entitled to another three hits. If such a ball goes "out," it is the fault of the team on the opposite side. A joust occurs when players of opposing teams cause the ball to come to rest above the net through simultaneous contact. A joust is not a fault, and play continues as if the contact were instantaneous (Rule 14.2.3).
  9. ATTACKING OVER OPPONENTS COURT: A player is not allowed to attack the ball on the opposite side of the net. When spiking, the follow through is allowed to cross the net without contacting the opponent.
  10. BLOCKING: Multiple contacts of the ball is legal during an attempt to block. Blocking a served ball is prohibited. Blocking is permitted after the ball is spiked, or intentionally directed toward the opponents side; or after the opponents allowable 3 hits; or after the opponents have hit the ball towards the net and no member of the attacking team is in a position to make a legal play on the ball; or if the ball is falling near the net and no member of the attacking team could reasonably make a play on the ball. Blocking a set ball before the spike is not allowable.
  11. PASSING AND RECEPTION OF THE BALL: Contact with the ball must be brief and instantaneous. Contact of the ball is permitted by the open hand, ball can not be lifted, held or thrown.
  12. PLAYER CONTACT WITH NET: Contact with the net either accidental or not is a fault. Hair is an exception. If the ball is hit into the net causing it to hit a player, such contact shall not be considered a fault.
  13. DEADBALL: The ball becomes a dead ball when: the ball touches outside an antenna, does not cross the net between antennas, strikes the floor or wall, contacts the ceiling or object attached to the ceiling which is 7 meters or more above the playing surface, a player commits a fault. A ball may be played off a lower ceiling or objects as long as it does not cross the net but is played on the same side. Net serve as long as ball passed between the antennas.
http://www.2005worldmasters.com/bcm/wmgame...3D?OpenDocument
thats it.. ur goin down *note to self dont wear any loose clothing that might come off to possibly distract opposition...*
ahahaha loose clothing is fine haha :)
anywhos i thought of a new sport................. we can commit to a full schedule of DnB gigs at heat, we will be getting a full body workout and sweat it out hardcore by the end of the night :D
so what ya think? :headspin:
for the slows who don't get it............. I'M JOKING
adrian ;)
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
    • I couldn't agree more. As an owner of a built high HP skyline, I'd be a hypocrite to not buy a Hummer for the reasons you listed though haha.
    • Hahaha oh shit! Again!
    • Is this the one? https://jpjdm.com/shop/index.php?id_product=2192&rewrite=nissan-stagea-c34-rear-boot-actuator-assembly-90550-0v000 Might be worth having a look at yahoo japan as well. Though it seems a bit odd. If the motor works itself, other than being noisy, then wouldn't it be more likely that it's an electrical issue somewhere else? And it being noisy does not seem as surprising if it has been chugging away for months
    • I know this thread is quite old, but I found it, it helped me, but I also wanted to add my experience and troubleshooting finds to the chat for others. I have not been able to open the rear hatch of my 97 Stagea for several months. Figured it had just really sealed itself up over the winter and I would just get to it eventually. Well that day was yesterday. Some time ago, I noticed my battery was going flat all the time. It was frustrating. Then one quiet night in the garage, I could hear and ever so slight humming / grinding noise coming from the back of the car. It was like a really quiet popping sound or something like sand in a very low speed blender. I took off the panels in the back and noticed the noise coming from the auto close motor, so I unplugged it and the noise stopped. And the auto close was disabled. Well, fast forward to yesterday, I tried all the tricks with power and fuse and lock and unlock and I still could open the damn hatch. So I took off the panels from the inside and found the auto lock had engaged and was stuck in close position. When plugging and unplugging the fuse, I could hear the relay clicking. So I plugged the autoclose motor back in, and the damn thing let go. And immediately started making that grinding sound again. This time, instead of just unplugging the motor, I pulled the fuse, thus depowering the relay entirely. I don't have the autoclose feature now, but at least I can open the boot and not have my battery being sucked dead all the time. Not sure what caused the motor to latch when it was unplugged from the system, but I am pretty sure it won't cause any more problems now.  If anyone has a lead on a new motor, please let me know. It's a cool feature that I would like to get back.  Hope this helps.
