Eunos 800M Manufactured by Mazda..
95/96 model
This is the flagship model featuring every conceivable option, no expence has been spared, this vehicle was priced at over $60,000 when new and released to be direct competion with BMW and Mercedes of the same era.
Featuring:
* 2.3 Litre Millercycle Supercharged V6 (as standard)
* Automatic with optional manual shift
* 4 Wheel Steer
* ABS
* Driver and Passenger Airbags
* Climate control A/C
* Bose 5 speaker surround sound with cassete and 6 stacker
* Power windows, mirrors, seats
* Electronic retractable mirrors
* 2-way sunroof
* Complete leather interior (front+rear+doors etc)
* Woodgrain inserts
* The vehicle has a feature that allows automatic regcharging of the battery through solar panels factory fitted in the sunroof
* Near new 18-inch chrome wheels
* Long Registration
This vehicle is in excellent condition and i have receipts for all work that has been done whilst in my care, the engine is mechanically A1.
It is a dream to drive, having both a very, very smooth ride and the availability of fast acceleration when needed at the same time is the most economical v6's i have ever driven (more like the fuel consumption of a 4 cylinder). It is a very elegant and stylish vehicle to drive and for the price
you would be very hard pushed to find anything else with these amount of options and to this standard of design on the market,
INSPECTIONS WILL NOT DISSAPOINT.
$14,500 ono
Enquires to-
0409288899
[email protected]
I do understand this is not a wrx , i have been a member on here for quite sometime now and have previously owned wrx's so i thought id give it a try- thanks.
****pictures are available, have tried hosting several time to no avail so if anyone could host for me it would be greatly appreciated*******
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
