LCD Monitors?? can anyone get good quality lcd for cheap prices???
yeah what he said... cause theyre not that smart when it comes to web sites..... as u can see lol.... all u had to do to see the platinum was remove the NON- from the pdf link and HEY PRESTO its the other prices... which is now the same
If you follow the links from the top level domain... they actually still have the "platinum members" login.... which uses a weak password hashing method... which is easily reverse engineered by viewing the source code :mad:
the user name and password are both "msy" :mad: lol I just access the linked page with the parts prices directly.
Let me know more details, i.e colour, budget, size and make and I can see what I can do. Can get most makes and will do you a good price. PM me if interested.
go into jb hi fi tomorrow and buy a new one for the marked price, then go to your car and put it in your car, then go back to the shop with your recipt and pick up another one and walk stright out with your recipt so if anyone asks you just bought it, then go to your car and take the othero ne out and go get a refund casue you made a mistake. works everytime
That's outright theft, mate. :thumbdwn:
JB always sell at the best prices anyway, so why would you encourage stealing?
If you want a good price. Best way is Walk into Digi world City... tell them what price other shop offer you and they will bet the price for sure. I been dealing with them for years now. Always get me a nice price. Go to the net check the price out, walk into digi world... boss this this this sell this this price. What urs. I want to buy it today.
any deal for x2 monitors? I'm looking at getting 17", x2. Bcos the viewable area on my 19" CRT is only a bit more, if not very similar to a 17" flat panel. So i'm thinking dual 17" Flat panels would be fine.
call me picky, but i'm after black or silver - not the obligatory biege :P
cheers.
cheers.
Yeah PM me mate with the above details and I will see what I can do. No reason why not mate though.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
