i wouldve thought with my mph that i couldve done a bit better...may need some more practise.. :rofl:
i was launching at about 3k...
R/T - .486
60' - 2.189
330' - 6.027
660' - 9.169
mph - 79.13
1000' - 11.816
ET - 14.067
MPH - 101.05
Km/H - 162.63
At the time, mods were..
Whiteline suspension
pineapples
full exhaust - hi flow cat, dump pipe and cat-back
GTR intercooler
lightened flywheel & ceramic clutch
stock boost
https://www.sau.com.au/forums/topic/61755-timesllip-does-this-seem-right/
Hey Adrian..
thanks for the advice.
When i slip the clutch, the ceramic combined with the lightened flywheel doesnt make the car too happy...thats why i was dropping it (as best that i could) at about 3k...
Im hoping the extra power the car is putting out will be controlled by the clutch if i slip it out while revving harder..
Hey Cameron - i actually thought my 60' was a bit lame. I would like to get it to a 2.0 flat..
Hey Adrian - Yep thats what im hoping for next time i hit the drags...My tyres are (unfortunately for drags) 18's....but i have 265's on the rear, so i may have a sporting chance...
Thanks SiksII - its great fun !!
i believe alot of it is how you drive your car and the track conditions at the time. my car ran 13.85 @ 101 miles/hr in Darwin of all places. it has similar mods, except i have standard clutch and no suspension mods at that time. Also still have stock intercooler. Like i said above, every 1 is different as to how they drive there car down the 1/4. It was 29 Degree's that night and the track is pretty slippery.
209kW and good tyres should see a high 12 if you can drive.  My car makes less power than that (193kW) and ran a 12.799 @ 105mph.
Adrian
Are u serious!?
first attempt at 1/4 about 6 months ago i did 13.8@104
spose that was launching at 2200rpm, but still your a second faster with 1 more mph :confused:
Are u serious!?
Yhe i agree with 2rismo. I ran a 13.4 @ 108mph wiht a clutch slipping in 2nd and 3rd gear, couldnt tell if it was clutch or wheelspin in 1st gear:( That was with a 2.4 6-ft time (i cant drive plus slipping clutch) and only around 180-200rwkws tops because if i ran more then 1bar then i had a miss.
So about 200rwkws (tops), slipping clutch and sh1tty 60ft i still ran a 13.4. Isnt the theory if i cut 3/10s of my 60ft then that equates to between 0.4-0.5 seconds thru the traps?!?!?! SO that means i woudl be looking at about a 12.9/13.0, then a clutch that didnt slip and im sure i would have been able to run a 12.8 (approx).
LOL, Splitfires and 1.4bar and i reckon i can give a 12.5 a nudge:)
There is a small but noticeable weight difference here. An R32 with 200 rwkw should run a fast ET than an R33 with 200 ya?
Looking around these forums I would hope to get 13.6 with my power except that then I remembered that I have a 4 door and it's heavier than a 2 door R34. Makes for better balance on the track but there is a little extra weight in it which may be making a difference on the strip.
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
