i wouldve thought with my mph that i couldve done a bit better...may need some more practise.. :rofl:
i was launching at about 3k...
R/T - .486
60' - 2.189
330' - 6.027
660' - 9.169
mph - 79.13
1000' - 11.816
ET - 14.067
MPH - 101.05
Km/H - 162.63
At the time, mods were..
Whiteline suspension
pineapples
full exhaust - hi flow cat, dump pipe and cat-back
GTR intercooler
lightened flywheel & ceramic clutch
stock boost
https://www.sau.com.au/forums/topic/61755-timesllip-does-this-seem-right/
Hey Adrian..
thanks for the advice.
When i slip the clutch, the ceramic combined with the lightened flywheel doesnt make the car too happy...thats why i was dropping it (as best that i could) at about 3k...
Im hoping the extra power the car is putting out will be controlled by the clutch if i slip it out while revving harder..
Hey Cameron - i actually thought my 60' was a bit lame. I would like to get it to a 2.0 flat..
Hey Adrian - Yep thats what im hoping for next time i hit the drags...My tyres are (unfortunately for drags) 18's....but i have 265's on the rear, so i may have a sporting chance...
Thanks SiksII - its great fun !!
i believe alot of it is how you drive your car and the track conditions at the time. my car ran 13.85 @ 101 miles/hr in Darwin of all places. it has similar mods, except i have standard clutch and no suspension mods at that time. Also still have stock intercooler. Like i said above, every 1 is different as to how they drive there car down the 1/4. It was 29 Degree's that night and the track is pretty slippery.
209kW and good tyres should see a high 12 if you can drive.  My car makes less power than that (193kW) and ran a 12.799 @ 105mph.
Adrian
Are u serious!?
first attempt at 1/4 about 6 months ago i did 13.8@104
spose that was launching at 2200rpm, but still your a second faster with 1 more mph :confused:
Are u serious!?
Yhe i agree with 2rismo. I ran a 13.4 @ 108mph wiht a clutch slipping in 2nd and 3rd gear, couldnt tell if it was clutch or wheelspin in 1st gear:( That was with a 2.4 6-ft time (i cant drive plus slipping clutch) and only around 180-200rwkws tops because if i ran more then 1bar then i had a miss.
So about 200rwkws (tops), slipping clutch and sh1tty 60ft i still ran a 13.4. Isnt the theory if i cut 3/10s of my 60ft then that equates to between 0.4-0.5 seconds thru the traps?!?!?! SO that means i woudl be looking at about a 12.9/13.0, then a clutch that didnt slip and im sure i would have been able to run a 12.8 (approx).
LOL, Splitfires and 1.4bar and i reckon i can give a 12.5 a nudge:)
There is a small but noticeable weight difference here. An R32 with 200 rwkw should run a fast ET than an R33 with 200 ya?
Looking around these forums I would hope to get 13.6 with my power except that then I remembered that I have a 4 door and it's heavier than a 2 door R34. Makes for better balance on the track but there is a little extra weight in it which may be making a difference on the strip.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
