Various Parts
Stock R32 GTS-T *Exhaust Manifold $20 ono
*Dump Pipe $15 ono
Jaycar 6.5" Splits (Silver ones) with crossovers tweeters etc. $40SOLD
Windscreen Wiper Motor $15 ono
Hicas Pump $20 ono
R32 Heater Motor $20 ono.
R32 Brake Master Cylinder $15 ono
R32 Clutch Master Cylinder $20 ono SOLD
R32 Ash Tray $10
R32 Grey Glove Box with Lock $10
Location Northern NSW 2460 will freight anywhere
ryan, its nic danger the guy who bought the turbo off you from ebay. mate that turbo was shagged it had cracks in bouth housings and the shaft was bent. i tried contacting you 4 times and never get a reply you told me the turbo was fine except some little chips on the exhaust wheel. you ripped me off and then didnt get back to me after my 4 attempts to contact you :argue:
I took the turbo to GCG turbochargers and they said they wouldnt even rebuild it as the housings were shagged.
Its funny how the internet is such a small place.
I ended having the turbo recod using new housings, shaft, bearings, thrust collar and plates. i had to pay $300 for housings and then $1100 for the reco.
I think i am entitled to some sort of compensation.
and if you dont want to refund me part of the purchase price then atleast work something out with me.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
