18" Rays TE37
To suit Nissan Skyline GTS-T (ECR33)
F: 18 X 8.5J +40
R: 18 X 9.5J +40
5 Holes PCD114.3
Wheels are in perfect condition, not a scratch!
Tyres:
F: 245/40/18
R: 265/35/18
About 40% treads left on tyres.
$3000 + Postage within Australia
STOCK IS HERE!!!
I'm registered and i have an ABN, tax receipt welcome!
https://www.sau.com.au/forums/topic/61786-18-rays-te37-for-ecr33/
  • 4 weeks later...
  • 3 weeks later...
Shonen: not quite the correct offset for a r34 but very close:( You'd be wanting roughly +37 and +38 to fit a GTT with this width. Might get away with +40 but I'd want to test that out first....
+38 offset is also for an R33. +40 offset will put the wheels inside the guards 2 much
