still having some trouble with my NA R33.
brief recap - had it for a year and ran great then suddenly started running really rough and belting out smoke from the exhaust, stalling on idle and dropping revs etc. used a heap of fuel.
put an aftermarket ECU in it and it resolved the worst of the problem, still threw out some smoke under hard acceleration and revved itself on idle etc would stall if i put the air con on. still used too much fuel
had a retune and adjust and seems better but now is stalling on cold start and still revs itself from 900-1100rpm, haven't tested the fuel tank yet but doesn't seem to have changed much.
i have been looking around the forums at similar problems and have noticed mention of coil packs popping up, some saying it is a common R33 problem with hairline cracks etc.
wondering - where they are? how much to fix/replace and what i can do to test if it is them or not?
any info is appreciated.
https://www.sau.com.au/forums/topic/61826-coil-packs/
not that i am aware of... where are the coil packs? what do they look like? if i can find them i will go ahead and wrap them or glue them.
pics or DIY?
SST tested pretty much everything on the car but i am trying ot think of what it could be, they said my O2 sensor was reading fine so i want to check the coil packs.
https://www.sau.com.au/forums/topic/61826-coil-packs/#findComment-1166854
under the black cover screwed down by allen keys in the middle of your engine it says nissan 2500 on it they are under there you can then un screw them individualy or the whole lot deprnding on what bolts you un screw i will get some pics later if you are still haveing trobule
you will need to take some small hoses off and the intake pipe first
https://www.sau.com.au/forums/topic/61826-coil-packs/#findComment-1167186
Once they have warmed up, you can test the resistance on them, OR
take it to nissan to plug it in and it should tell you.
For the first method, do a search, it is covered in detail.
taping or gluing doesn't really cost more than a few bucks. If it works, then you know they were the culprit to begin with.
Obviously new coils are the better option, but if you can save a few bucks, it is worth a try...
what does glueing or taping your coil packs do?
if the coils have a crack (which most do after X amount of km or years) then the spark can arc from the crack in the coil, onto the head, meaning you will get considerably less spark to your plug, and it will not ignite the fuel entirely. This causes misfire.
The coils being made of a thermo plastic, cant be plastic welded, so they need to be covered with some sort or epoxy that will stick. If you look at the back of each coil pack, they actually come covered with an epoxy, so using araldite (which is an epoxy) should be fine.
https://www.sau.com.au/forums/topic/61826-coil-packs/#findComment-1167515
cheers for the info, pics would be a help but i'll take a look this weekend.
https://www.sau.com.au/forums/topic/61826-coil-packs/#findComment-1167719
The araldite cost me about $12 and it took me about 4 days to do. I'd take 1 out, glue it up, put another spare coil in so i could still drive my car whilst leaving the other coil to dry for a solid 24hrs in the sun (if you put them back in any sooner the araldite glue will just drip all over everything so take your time and do 1 at a time).
/waiting on Splitfires from Nengun :cheers:
https://www.sau.com.au/forums/topic/61826-coil-packs/#findComment-1170432
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
