Hey everyone.
After really getting know where with kits for four door R32's, I've decided on going with a stockish looking body, as that’s what I had on my R32 coupe and was quite happy.
After searching for "Type-M" style skirts for the 4dr I came across these on car domain. Does anyone know where I can pick up a set, I have looked at getting some modified off a coupe, but it might just be easier trying to find real one's. I’ve seen a few sets on Yahoo months ago.. But haven't for a while now.
If any one can help, that’d be great!
Cheers, Josh.
https://www.sau.com.au/forums/topic/61841-type-m-skirts-for-the-four-door-32/
