No probs Matt, you're off!
IMO they're not worth paying more than $200 for as its not a huge upgrade over the stock ones. If I can get them for close to $200 I will be happy but if the cheapest is $300 or more then I don't think its worth it.
Still haven't heard back from Greenline.
Nengun haven't replied at all, nearly a week later.
Haven't heard from MSI or another supplier in Melb yet either!
Will have to do the ring around I think, these people don't seem to respond well to email!
  • Replies 47
It's not like an Official Group Buy at this point anyhow.
If I can get the part cheap, whoever is interested can buy one at the time :rant:
Although there is no great news I thought I would update the thread, so you know I am still working on it ;P
Prices are NOT looking good so far:
One supplier has quoted me $440 each and another supplier said $950!!! Though I suspect this is incorrect - he wasn't a sales person and the right person will be calling me back.
So far:
MSI $200 - can't get in touch with
Greenline $374 - still waiting for bulk pricing
XXXX: $440 - ?
XXXX: $950 - prefer not to name them yet cause I usually get good quotes :rant:
Nengun: $??? - no response to email yet!
XXXX: $??? - no response to email yet!
For reference Nismo list them @ 29,400 Yen ~ $371 AUD
Since it's Nismo you should be able to get it through Nissan. I think we have a good contact at a Nissan dealership up here.
If you want me to look into that pm me.
666DAN / HKS34R: These pics should help :rant:
Thankyou NismoR34.
As I have never seen one of these consoles, how big are the gauges?? I'm looking at getting one of these to host a series of aftermarket gauges, cos it looks stock, hence no defects. Would HKS or Blitz gauges fit??
:rant:
HKS34R:I believe blitz & defi have gauges that fit into the console, can't remember size though - its bigger than 52mm, the 60mm gauges are probably the best fit.
AboBob: PM'ing you now!
If you can get me a part number and indicate how many units you are interested in purchasing, I can call around and get a price for them locally.
Nismo Part number: 24845-RNR40
Minimum 3 units at this stage, given some time, maybe more.
Thanks!
Just waiting on my friend who used to work for Nismo to get back to me with some contact details for someoen who may be able to help. It may take a couple of days, but I will get some kind of answer, as soon as I can...
Cheers..
Hey, IM also trying to work out a deal on some Carbon Fiber bonnets at the moment. Once I have all the details I may put together a group buy... what do you think? I already know I can get them and for a reasonable price. its just the shipping I am concerned about...
Depending on the price of these bonnets I may be interested :D
Don't have heaps of cash atm but yeah let us know approx cost when you can - even a before shipping cost will help! Cheers.
Greenline have quoted me a much better price for 5+ units ordered: $310 each - approx at current exchange rates!!
Obviously we would need 5 people to get that price though.
Still waiting for 3 guys who are chasing up prices for me by various avenues :cheers:
Much appreciated!
Dale
Sorry for the delay getting back to you.
I got a price directly from Nismo, but its a bit more than what Greenline have quoted. For 5+ it would be about $330 at todays exchange rate. I was warned by Nismo to look out for cheaper fakes that are going around, so I thought I would pass on that comment.
Cheers,
LegnumVR4
Havent had time to chase up the last 1 or 2 contacts for quotes, its looking like $310 odd [greenline] is the best I am going to get!
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
