Best dealers for skylines
  • Replies 179
  • 7 months later...
i bought my r34 25gt from there for 13,000, i checked everything and took it for a drive the only problem was the centre console's hinges were broken while everything else was perfect. ive had it for 2 weeks now and loving it ill definately go there again, he gets new cars in there all the time, turbo's and n/a's i'd recomend them to other people.
yea i got my car (r33gts-t 2) from power road and the guy there shane is pretty good on the whole.
very casual though dunno if thats a good thing when your putting down your hard earned (nearly let me walk out the day i picked it up without giving him his cheque :laugh: ) good thing is if your serious he will let you drive about every car in the lot without a worry duno maybe its an aussie thing just seems so not fussed with it all lol
when i was browsing around, he didnt approach me until he saw me with my dad. Let me test-drive r32's and was happy to take car to any mechanic for a pre-inspection.
Although one problem i had was he listed a car as 1993 when it was a October 1992. May not be a big deal but i wanted a genuine 1993 model.
I guess that's why he didn't talk to me, didn't take me seriously (I wasn't serious on buying any cars anyway :P ).
Just like Pablo101 Power Rd are the only dealer with r34's in my price range too. :thanks:
Went down there last week and a guy called Jeff was the first to approach me.
Unlike Shane, this guy knows exactly how to look after a customer!
In about 5 mins of looking at the only R34 25gt there he threw me the keys to let me have a drive (trusting an 18yr old with an R34 within 5 minutes in my opinion was somewhat of a miracle).
NO pressure at all to commit and he even bought my girlfriend and myself a powerade!
As far as i can tell their cars are pretty good (apparently all grade 4 auction ratings at least), although their yard isnt the most pleasing to the eye.
This thread is really coming along since its revival !
Keep the comments coming they're really helpful as i need all the info i can get before i buy my first car (and incidently first 'line :banana: )
hey guys, currently in the market for an series II r33. JSA is bad i was gona smash him... he was full of crap. I went to JAPCARs which is on the humeway they seemed to be ok,nice r32's and 33's but some of them had dints n repsrayed... anyway today i went to power road.. they had some nice skylines... im thinking of purchasing a s2 r33 2morow. I will tell u guys the outcome. Thanks so much for the information ;)
Geraus.
best place to buy skylines in my opinion is power rd car sales.
I had my R32 GTR imported by him. It was a grade 4 and was the best R32 GTR i could find anywhere.
they have a good selection and the prices are very competitive.
customer service is not the best but once they know you are serious, its all good
I paid 18k for my GTR
was it the burgandy one?
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
