this is how i have my gauge, i didnt want it to cause any blind spot or stand out to much so i built this with fibre glass and putty, i think it came out pretty good, not finished yet (this was a trial fit) what do you guys think?
hey looks pretty good, its like at the angle i want mine to sit at, actually facing me unlike the a-pillar pods you buy. did u buy it and modify it ? would you be willing to make any more :) lol
i made it from scratch, using pvc pipe, t shirt cloth and fibreglass resin, once i got the basic shape i liked i used body filler to get it smoth, then painted it. ( not completly finished yet) you could cover in leather or any other material aswell
if you live in perth i can help you make it.. otherwise pm me and i will give you help that way
Don't know where to mount the gauge but with respect to the AVC-R:
Thinking about mounting inside the Drivers Sun-visor. 3 reasons...
1) When not need it can be folded up and the AVC-R is out of site… Stealth install- less attractive to thieves (out of sight- out of mind).
2) When you do need to use it- if while driving- fold down the sun-visor and it’s direct line of site… don’t need to take your eyes of the road…
3) How often do you see mounted there?
Problems-
1) Running the cable from the appropriate areas up the inside of the drivers “A” pillar then into the visor.
2) Thickness and weight of the AVC-R would probably require the visor to be cut and some bracing inserted. It probably would not sit flush either.
I know it sounds like a big job but if people can do it to Mini TV’s you certainly can mount AVC-R. Your effort = Your time and money.
Also if you have the AVC-R (Air Volume Controller ?) it comes with a boost display. There for don’t require the boost gage- sell it and it’ should pay for some of the sun visor modifications.
My idear when I finly get my line...
Stuck with VL for now
anyone got sum pics of it mounted on a sunvisor?
I agree pics i want pics of the avc-r on the sunvisor ;) i thought of it and went hmmm nar, but if i can see pics that would be bloody awesome :(:D so come along people, get some pics rolling on :D
  • 1 month later...
hey guys, soz to dig this thread up again, but has anyone looked at mounting a boost gauge in the air vent on the right hand side of the steering wheel?? I have seen it done in a rexxie, but not sure if it would be possible in a R32, and i cant check it coz i aint got mine in OZ yet.
If some1 has done it, i would be keen on a pic of how it looks, or even just a measurement of the air vent itself would be kewl to see if it is possible...
cheers.
NAman - AVC-R stands for actuator valve controller type-r
oRiCLe - a 60mm gauge fits in there. I've got one there.
Attached is a really bad shot of my interior (it's really small as well). If I remember I'll take some photos of it tonight.
yeah, it's a pretty cool stealth set-up. Not my car though. It belongs to a friend of mine, in his GTI-R.
The flap was taken from another sun visor and is held either up, or down with magnets.
Yes, AVC-R does display boost graphically.
here's another pic of the visor with the fabric off. He cut out a recess for the AVC-R and cable and mounted it in.
that should give you some inspiration as to what is achievable.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
