this is how i have my gauge, i didnt want it to cause any blind spot or stand out to much so i built this with fibre glass and putty, i think it came out pretty good, not finished yet (this was a trial fit) what do you guys think?
hey looks pretty good, its like at the angle i want mine to sit at, actually facing me unlike the a-pillar pods you buy. did u buy it and modify it ? would you be willing to make any more :) lol
i made it from scratch, using pvc pipe, t shirt cloth and fibreglass resin, once i got the basic shape i liked i used body filler to get it smoth, then painted it. ( not completly finished yet) you could cover in leather or any other material aswell
if you live in perth i can help you make it.. otherwise pm me and i will give you help that way
Don't know where to mount the gauge but with respect to the AVC-R:
Thinking about mounting inside the Drivers Sun-visor. 3 reasons...
1) When not need it can be folded up and the AVC-R is out of site… Stealth install- less attractive to thieves (out of sight- out of mind).
2) When you do need to use it- if while driving- fold down the sun-visor and it’s direct line of site… don’t need to take your eyes of the road…
3) How often do you see mounted there?
Problems-
1) Running the cable from the appropriate areas up the inside of the drivers “A” pillar then into the visor.
2) Thickness and weight of the AVC-R would probably require the visor to be cut and some bracing inserted. It probably would not sit flush either.
I know it sounds like a big job but if people can do it to Mini TV’s you certainly can mount AVC-R. Your effort = Your time and money.
Also if you have the AVC-R (Air Volume Controller ?) it comes with a boost display. There for don’t require the boost gage- sell it and it’ should pay for some of the sun visor modifications.
My idear when I finly get my line...
Stuck with VL for now
anyone got sum pics of it mounted on a sunvisor?
I agree pics i want pics of the avc-r on the sunvisor ;) i thought of it and went hmmm nar, but if i can see pics that would be bloody awesome :(:D so come along people, get some pics rolling on :D
  • 1 month later...
hey guys, soz to dig this thread up again, but has anyone looked at mounting a boost gauge in the air vent on the right hand side of the steering wheel?? I have seen it done in a rexxie, but not sure if it would be possible in a R32, and i cant check it coz i aint got mine in OZ yet.
If some1 has done it, i would be keen on a pic of how it looks, or even just a measurement of the air vent itself would be kewl to see if it is possible...
cheers.
NAman - AVC-R stands for actuator valve controller type-r
oRiCLe - a 60mm gauge fits in there. I've got one there.
Attached is a really bad shot of my interior (it's really small as well). If I remember I'll take some photos of it tonight.
yeah, it's a pretty cool stealth set-up. Not my car though. It belongs to a friend of mine, in his GTI-R.
The flap was taken from another sun visor and is held either up, or down with magnets.
Yes, AVC-R does display boost graphically.
here's another pic of the visor with the fabric off. He cut out a recess for the AVC-R and cable and mounted it in.
that should give you some inspiration as to what is achievable.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
