Hey,
I finnally have a NON-Busy weekend coming up! and was going to fit my new HKS 2530 turbo to my R32 GTST! The plan is to get a Power FC (will be a few weeks off yet) injectors are in the mail as week speek!
I was just wondering if the standard ECU (mines Chiped) and standard injectors would be able to work propperly if i just putt the car around eg. work n back etc.. untill the Power FC & New injectors come???? Then Of course ill get it all tuned up!
P.S. The new fuel pump went in last weekend!
Thanks
Luke
https://www.sau.com.au/forums/topic/61925-hks-2530-standard-ecu-mines-chiped/
heres what i have and i am running a standard remaped ECU....the ecu was remapped before all of these mods ......HKS 87mm step 2 pistons,hks 264 10mm lift cams,hks cam springs,Nismo head gasket,Nismo oil pump,oil restristor,HKS rods,CARR rod bolts,lightned knife edged and polished crank,trust plenum,HKS exhaust manifolds,HKS dumps,HKSGT2530's,OS quad plate clutch,ARP head studs,nismo fuel pump,HKS cam gears and i made my own swinging baffle for the sump....it runs a touch rich ....yours should be fine
Wicked, Thanks guys!!!
Putting around will suck though
Aww well!...ill put up with it!
Throw it on the dyno for a cheapo power run to check the afr's on low boost.
Might surprise you :D
Price around though as prices varied from $145 right down to $35.
Hey guys,
Turbo installation went well on the weekend!
Now im just abit too nervice of driving it as i dont want it to run lean!
I have an SAFC-II and was going to just pump the fuel up abit, just incase i do hit alittle bit of boost! ANyone got any ideas as to what percentage i should pump it upto? i had it on 10%+ correction but wasvery unsure! This is only tempary for a week or two! and id rather it alittle rich than lean (as you would expect)
Any help would be greatly appreciated!!!
Thanks Luke!
yeah, im driving my sisters car around! Im still waiting on my Power FC to come from nengun!
The Wastegate arm is set to 1.2bar..so its abit hard to turn the boost down
Thanks for u r help!...Not driving the skyline sucks so much ;)...aww well
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
